^ agreed. Your charcoal canister is loaded with gas fumes, which is causing your gas filler to do that. The purge solenoid doesn't contain enough voltage to charge the coil, releasing the gas fumes back into the intake, which replacing it should help. Also, AutoZone's scan tool is just a generic scanner, cheapo. If you want to see what its supposed to read, get one that has access to PIDs to read the voltage on each sensor/actuator. Most generic scanners with PIDs will be for this particular DTC, EGR & EVAP Emissions Control. Should read above .1v-5v max for reference (5v=signal voltage at max load, .1v=lowest reading and solenoid closed).
