190 Degree Water Temp Readings. Safe? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 06-22-2013, 03:58 PM Thread Starter
djryanss's Avatar
Send a message via Skype™ to djryanss
I am getting readings of 190 for my water temp through scan Gauge 2. Is this safe or a sign my intercooler pump is not operational?
Audio Mods:
Pioneer DEH-X8500BH HU with USB Input install, Kicker KS62's, Alpine Type S 6x9's
Interior: Under Construction
Exterior Mods:
Debadged
3 side Tint
Wind Deflectors
Engine Mods:
Vibrant Performance 4-2-1 Headers
Cold Air Intake w K&N Air Filter
Siemens 42# Injectors
2.7" Quick Change Pulley
http://www.syndicateoftuners.com
djryanss is offline
post #2 of 8 (permalink) Old 06-22-2013, 05:51 PM
09cobalt 2.2's Avatar
My 2.2 reads almost 205 on a hot day never had a problem with
09cobalt 2.2 is offline
post #3 of 8 (permalink) Old 06-22-2013, 05:59 PM
AHODA's Avatar
Hey man seems like we are having the same concerns again.
I just posted mine under the thread by 'fosterone' about his 2007 running hot.
I think you're asking the same question. But not sure by what you mean 'scan gage 2' and I don't have the intercooler.
I am concerned b/c mine got up to 216* today and the fan didn't come on. Just trying to see if that's normal. Seems pretty hot to me. And when does the over-heat light come on? Searched for an answer but no luck.
CURRENT RIDES
2006 Chevrolet Cobalt LS, (2.2L), 5 speed
1971 Chevy C20 Longhorn (6.6L, 402c.i.BBC)
PAST RIDES
1973 Chevy K20, 4x4, std. cab, longbed (350c.i.);
1979 Chevy Corvette (350c.i.);
2001 Chevy Xtreme S-10, ex-cab, 5spd. (4.3L);
2001 Chevy Silverado 2500HD, 4x4, ex-cab, (6.0L);
2002 Chevy Silverado 1500, ex-cab, 4-6drop (4.8L);
2003 Chevy Silverado 1500, 4x4, std. cab, 5spd (4.8L);
2004 Chevy Colorado Z71, 4x4, crew cab, (3.5L);
2006 HUMMER H3, 4x4, 5spd., (3.5L).
AHODA is offline
post #4 of 8 (permalink) Old 06-22-2013, 06:05 PM
Fan does not come on till rediculous reading, flip the a/c on when it goes up, that kicks on the fans. I know 2.2 and maybe 2.4's normal temps are between 187-195 depending on weather conditions. I had a couple of 2.2's and hated the fan not kicking on till very high temps. My Supercharged ran at 178-80, anytime it got up till around 190, usually while idling/sitting in slow traffic I would just hit the a/c and it'd go back down. I would say its normal but there could be something wrong if you are driving with fresh air coming in and its still reading high.
post #5 of 8 (permalink) Old 06-22-2013, 07:36 PM
09cobaltltsport's Avatar
I've gotten mine up to 235 with no problems at that temp
Future mods:
chevy 572 c.i. motor insatall
09cobaltltsport is offline
post #6 of 8 (permalink) Old 06-22-2013, 07:39 PM
biniecki's Avatar
Mine use to get up to 205 or 210 before the fans would kick on. I ended up wiring a manual override to turn it on whenever I wanted.
2006 Cobalt LS 2.2L Ecotec
Show Off Thread
biniecki is offline
post #7 of 8 (permalink) Old 06-26-2013, 11:20 AM Thread Starter
djryanss's Avatar
Thanks for all the reassuring input..
A ScanGauge 2 is a very.....limited OBD2 device. Displays RPM, HPR ect ect. Also get's Codes and Can clear them as well. I may let mine go if your interested in the basics. Not good if your looking for A/F ratio's
Audio Mods:
Exterior Mods:
Debadged
3 side Tint
Wind Deflectors
Engine Mods:
djryanss is offline
post #8 of 8 (permalink) Old 06-26-2013, 02:57 PM
kmac's Avatar
Stole this from .net:
This should answer your Question.
The ECM commands Low Speed Fans ON under the following conditions:
Engine coolant temperature (ECT) exceeds approximately 106C (223F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off, the ECT at key-off is greater than 140C (284F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
ECT reaches 110C (230F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
kmac is offline
