09 2.2 Ls Throwing Up Too Many Codes to Be Coincidence. - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 19 (permalink) Old 08-12-2013, 07:04 PM Thread Starter
Tokymaru's Avatar
My 09 ls seems to be throwing up too many codes for everything here to be going wrong at once.
I had a tire separate, and it took the inner fender with it. When I pulled over, it was wrapped around the axle/ suspension. Nothing looked damaged so I put the spare on and drove home. Everything seems fine, but, but about a day after I put new rims and tries on it a few days later (it was already planned, so I wasn't too bent out of shape about the separated tire) it started throwing up trouble codes left and right. I tried resetting the ecm and they come back as soon as the car starts moving again.
O'Reily's didn't give me the specific codes I had, but had mentioned the o2 sensors and the maf. I dug out my pos obdII scanner and got the codes, but it doesnt show the last digit of each, but from reading through the list of dtcs, it looks like they're;
P0031, P0032, P0051, P0052, P010?, P013?, P014?, and P044?
Would the tire have anything to do with this, maybe having knocked a ground wire loose or something? Could all these things really be wrong, or is there just a simple solution(hopefully). I need to get this taken car of, my inspection is up this month, and I can't get it inspected until there's not CEL.
Tokymaru is offline
post #2 of 19 (permalink) Old 08-12-2013, 07:30 PM
Looks like you blew the Exhaust voltage fuse. Check in the underhood fuseblock. This fuse supplies voltage to the HO2s and MAF sensor plus a few others like MAP and intake temp
post #3 of 19 (permalink) Old 08-12-2013, 09:06 PM Thread Starter
Tokymaru's Avatar
I had read that on another site. I thought I had checked all the fuses before, but I guess I missed that one. Went out to double check, saw it was blown. reset the ecm and let it run for a few minutes. Seems to be working now. I have to go pick up my fiance from work here in about half an hour. Will report whether the MIL comes back on.
Thank you for the help.
---------- Post added at 11:06 PM ---------- Previous post was at 10:01 PM ----------
Well, down the road and back and no codes. Thank you Coby for that bit of knowledge which has potentially saved me a ton of money.
Tokymaru is offline
post #4 of 19 (permalink) Old 08-12-2013, 10:10 PM
"You just saved a bunch of money on your mechanic bill by switching to forums"
post #5 of 19 (permalink) Old 08-22-2013, 03:30 PM
electrical problem!
wont turn over,
fuel gadge wont read
low fuel warning
powersteering warning
battery is fine conections fine
im wondering what is incharge of fuel sending/reading
ECM- tryed a used one fuel still wont read (NO CHANGE
TCM- in mail will arive in few days
BCM- looking for a cheap new one
trying to figure it out before i take it to the dealer I know they will have to program things like ecm, tcm, and bcm
09cobaltsedan is offline
post #6 of 19 (permalink) Old 08-22-2013, 04:37 PM
I think you broke one of the two engine grounds or both, the one in front where the transmission and engine bolt together. This is the ground for TCM and ECM, also for fuel sending unit and a bunch of sensors too.
post #7 of 19 (permalink) Old 08-22-2013, 05:12 PM
coby is my hero
post #8 of 19 (permalink) Old 08-22-2013, 07:54 PM
thanks Coby! I will be able to check the ground conect. this weekend
post #9 of 19 (permalink) Old 08-26-2013, 10:15 AM
Ok so I checked all the grounds and cleaned them, Same problem no change. Car wont turn over fuel gadge wont read, ps warning, abs warning, low fuel warning, any ideas????
should I check if the ECM is getting power? and if so how?????
post #10 of 19 (permalink) Old 08-26-2013, 10:30 AM
Levee
Admin
Leveecius's Avatar
Checking for power to the ECM is easy. Get the wiring pinout for the ECM, find the power and ground wire and use a volt meter and connect leads, will tell you if you're getting voltage. Sounds like a ground to me, but could be the ECM going out.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
