P0303 Code -Can Anyone Decipher Torque Results - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 08-12-2013, 07:20 PM Thread Starter
Question P0303 Code -Can Anyone Decipher Torque Results
My 2008 Cobalt has a Cylinder 3 misfire code, P0303. I've changed spark plugs and coil packs, which didn't help. I have Torque and ran some testing, but I have no idea what the results mean. Can anyone help, please?
Mode $06 report generated by Torque for Android
Vehicle VIN: 1G1AL58F587271388
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 126
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.4281V** Min: 0.4281V
Test result value: 0.4281V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.45018V** Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.65026V** Min: 0.65026V
Test result value: 0.65026V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Test incomplete or dependant test failed
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 24ms** Min: 0ms
Test result value: 0ms
PASS
MID:$01 TID:$80
MID:$01 TID:$81
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 800Count** Min: 0Count
Test result value: 0Count
PASS
MID:$02 TID:$8b
MID:$02 TID:$8c
MID:$02 TID:$91
MID:$02 TID:$92
MID:$02 TID:$93
MID:$10 TID:$da
- O2 Bank 4 Sensor 4
Max: 41,190ms** Min: 4,144ms
Test result value: 55,824ms
FAIL
MID:$12 TID:$b0
Max: 2,730** Min: 0
PASS
MID:$18 TID:$02
MID:$18 TID:$12
Max: 0.03052%** Min: 0%
Test result value: 0%
PASS
MID:$21 TID:$4d
- Catalyst Monitor Bank 1
Max: 0mHz** Min: 4,177mHz
Test result value: 19,744mHz
FAIL
MID:$21 TID:$a0
MID:$30 TID:$da
Max: 62.85594%** Min: 6.32374%
Test result value: 85.23625%
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
MID:$3a TID:$c1
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
MID:$3c TID:$ca
MID:$3c TID:$cb
MID:$3d TID:$c4
- EVAP Monitor (0.020")
MID:$3d TID:$c5
MID:$3d TID:$c6
MID:$3d TID:$c7
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count** Min: 0Count
PASS
MID:$41 TID:$d3
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
MID:$50 TID:$db
- O2 Heater Monitor Bank 4 - Sensor 4
Max: 41,190** Min: 4,144
Test result value: 56,144
FAIL
MID:$70 TID:$d8
Test result value: 55,408
FAIL
MID:$81 TID:$2b
- Fuel System Monitor Bank 1
Max: 170** Min: 0
PASS
MID:$82 TID:$5d
- Fuel System Monitor Bank 2
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count** Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 3,135Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$b0 TID:$da
Max: -74.30399%** Min: 12.64749%
Test result value: -29.1527%
FAIL
JCY7782 is offline
post #2 of 5 (permalink) Old 08-12-2013, 07:50 PM
P0303 is a still unresolved ECM bug in the DTC system. If you look at these lines;
MID:$a4 TID:$0c
PASS
You will notice that with a sample of 65,535 your car had 0 misfire, yet it registers a count of 3,135 total misfires. ????? Then it goes on to say it pasted the test.
So if there's nothing wrong with cylinder number 3 what is wrong??? I believe it has to to with a CAM - CPS sensor correlation problem. You would need to put a scope on these to find out if one of them is losing it's square wave momentarily causing the ECM to check cylinder number three for misfire when cylinder number 3 isn't even on the firing stroke. Don't know if Torque shows these or not in the list of sensors.
post #3 of 5 (permalink) Old 08-12-2013, 10:12 PM
Does your engine shake at all, or slightly knock or tick? If so, you bent a valve. If not, I'm gonna blame injectors. Switch injectors with cylinder 4, delete the code and see if it follows. Do the same thing for your coilpack
post #4 of 5 (permalink) Old 08-13-2013, 02:25 PM Thread Starter
Thank you, I am still learning Torque - so I will have to look. Yes, the car has a terribly rough idle, and shakes/knocks when I'm sitting in traffic, waiting at a stop sign, etc.
Also, my service traction light is constantly on - not sure if that's related.
JCY7782 is offline
post #5 of 5 (permalink) Old 08-13-2013, 03:49 PM
Sure it is, this means your losing GMLan communications between CPUs. Try pulling every single fuse and flipping them before re-inserting back into place. You might be experiencing a common problem with BCM corrosion. Give it a try, it's easy and solves problems 60% of the times.
cobalt , misfire , p0303 , tests , torque
