08 Heating Up While Idling - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 11 (permalink) Old 10-17-2013, 08:04 PM Thread Starter
LiannaMc1's Avatar
Question 08 Heating Up While Idling
While I'm driving my car stays around 194-198...while idling, it went up to 220. I left my car idling in my drive way, popped the hood, and the radiator fan wasnt running. Would anyone have any idea on what might be going on with my car? It just started doing this, so if its bad, i want to catch it before it makes anything worse.
LiannaMc1 is offline
post #2 of 11 (permalink) Old 10-17-2013, 08:42 PM
Jmesl8er's Avatar
220 isn't bad
Jmesl8er is offline
post #3 of 11 (permalink) Old 10-17-2013, 09:08 PM Thread Starter
LiannaMc1's Avatar
Should i keep an eye on it if it goes higher?
Its never done this before, I've only had it a little over a year.
post #4 of 11 (permalink) Old 10-18-2013, 09:56 AM Thread Starter
LiannaMc1's Avatar
So, this morning, I popped the hood and noticed my radiator fan isn't running while idling...
post #5 of 11 (permalink) Old 10-18-2013, 10:01 AM
Hit the a/c on, the fans should kick on if the a/c or defrost is on. If not you might need to have it looked at. They tend to not kick on to cool down till 215 or hotter.
post #6 of 11 (permalink) Old 10-18-2013, 11:38 AM Thread Starter
LiannaMc1's Avatar
Awesome! I went out and did it, the fan kicked on with the ac.
I'm hoping this is just one of those moments where I never noticed the temp until now.
And I also really appreciate your help, I'm trying to learn as much as I can to do repairs on my own.
post #7 of 11 (permalink) Old 10-18-2013, 11:47 AM
All normal. Here are the specs.
The ECM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106C (223F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140C (284F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
• ECT reaches 110C (230F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
post #8 of 11 (permalink) Old 10-18-2013, 11:56 AM Thread Starter
LiannaMc1's Avatar
All of this...just...I'm the happiest girl in the world right now!
post #9 of 11 (permalink) Old 10-18-2013, 12:01 PM
and you are
post #10 of 11 (permalink) Old 10-18-2013, 01:06 PM
yea, with both of my balts(technically had 3) when I idled and saw temps go above 190* I would hit the a/c to keep them around there. 200s and such may be normal but I do not like running hot. Learned my lesson with gm back in my cavalier days when the fan never came on till my temp gauge was in the red.
