P0128 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 22 (permalink) Old 11-19-2013, 04:50 PM Thread Starter
Clarky215285's Avatar
P0128
Tonight I was driving my 05 balt base coupe at 65MPH with the outside temperature being 33oF and coolant temperature changing between 167oF-180oF. My check engine light came on and gave P0128 code about the coolant temperature sensor. I have cleared it and drove 6 more miles and it hasnt come back. What could be the cause for this?
Clarky215285 is offline
post #2 of 22 (permalink) Old 11-19-2013, 05:11 PM
Bad ground. Mine does it all the time. I just delete it and move on. Its a bitch to start when the code is on though, I'd suggest pulling your fan relays prior to attempting to start when you don't have access to a code reader
post #3 of 22 (permalink) Old 11-19-2013, 05:47 PM
Chances are if you've never changed the thermostat that the rubber seal that runs around the opening has started to deteriorate to the point that coolant flows by and the thermostat can't bring or keep your engine at proper operating temperature which should be around 193F.
---------- Post added at 09:46 PM ---------- Previous post was at 09:31 PM ----------
https://www.yourcobalt.com/forums/pro...ode-p0128.html
---------- Post added at 09:47 PM ---------- Previous post was at 09:46 PM ----------
https://www.yourcobalt.com/forums/pro...-shopping.html
post #4 of 22 (permalink) Old 11-19-2013, 06:52 PM Thread Starter
So it sounds like I need to replace my thermostat. Ugh I just flushed my coolant like two months ago too. Is there a "How-to"?
post #5 of 22 (permalink) Old 11-19-2013, 07:51 PM
I replaced my thermostat and it does it all the time. Dont give up hope on something simple. Delete the code and see if or when it comes back
post #6 of 22 (permalink) Old 11-20-2013, 05:35 AM
06slobalt's Avatar
Turn on your car. Blast the hot air. Squeeze the rad hose that goes the the block. Cleared the code and hasn't come back since
06slobalt is offline
post #7 of 22 (permalink) Old 11-20-2013, 12:33 PM Thread Starter
The light came back on while driving like before
post #8 of 22 (permalink) Old 11-20-2013, 01:12 PM
06slobalt's Avatar
post #9 of 22 (permalink) Old 11-20-2013, 06:00 PM Thread Starter
is there a how-to? Where exactly is the thermostat located on a 2.2L Base? Photos?
post #10 of 22 (permalink) Old 11-20-2013, 06:35 PM
Its right above the transmission on the top rear where the bellhousing and motor mate up
