06 Stutter/hiccup at Cruise Speeds Only No Codes - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 12-16-2013, 08:44 PM Thread Starter
I have an 06 with 118,000 miles on it, 2.2. I have searched extensively and have not found a problem exactly like mine. I had a code for the O2 sensor and got it replaced along with my transmission cooling lines (transmission was a quart low). Right before I took it in I noticed that the car was stuttering at a cruising RPM. I was worried that it was the transmission slipping and stopped at a gas station and had it towed to a dealership to get fixed. I got the car back and it ran fine but I put a bottle of Heat in it thinking the problem might have been water in the lines as the temp was below zero for a few days that week. It was fine for a few days but the first time I got it on the highway it did it again. It was really bad at first, especially while accelerating up the on ramp but then smoothed out at 65. It stuttered about 4 or 5 times on a 30 mile trip, some worse then others, but happened more frequently when I tried to go over 70. I drive the car to work every day and it doesn't happen very often, maybe twice per trip, but comes back more frequently whenever I take it on the highway. Everything else seems to be fine and it idles smooth. I have held the accelerator around 3000 in Park with no effect. The check engine light does not come on and there are no codes. Also, there is no change in the tach so I do not think it is the transmission or it happens so fast it doesn't register. Right after it skips, the tach rises just a little as if then engine is trying to overcompensate for a stall. Any suggestions would be greatly appreciated. I'm thinking of buying the car a pacemaker and seeing if that helps.
Chicayne is offline
post #2 of 5 (permalink) Old 12-16-2013, 08:54 PM
Sounds like torque converter shutter to me
CamaroSS1969427 is offline
post #3 of 5 (permalink) Old 12-16-2013, 10:17 PM
Batmobile's Avatar
Have you cleaned the throttle body ever? It could be very dirty with the miles you have. Even if it isn't the problem, it would be good to clean it.
Batmobile is offline
post #4 of 5 (permalink) Old 12-17-2013, 07:04 AM
I would agree on the TCC. Sounds like the torque converter clutch is slipping on cruising speeds for when that's the only time its supposed to be engaging. I would have that checked out at the stealership and their Scan tool should have access to the TCM (Transmission Control Module). They should "verify" your concern and have the scan tool on readiness monitors for the TCM and BCM, and drive on the freeway to see if it engages or not. Should look like this on their Scan Tool:
Readiness Monitors:
ABS (Anti Lock Brakes) On/Off
SS (Shift Solenoid) 1-4
TCC (Torque Converter Clutch) On/Off
WSS (wheel speed sensor)(LF, LR, RR, RF) **MPH
Gear (L-R, 1-2, 2-4, UD, OD)
post #5 of 5 (permalink) Old 12-17-2013, 07:41 AM Thread Starter
I would agree with the shudder if it wasn't happening on below zero days and getting better as the car warms up. I am going to try changing the coil and plugs and see if that helps, if not I will go to the dealer and have them check the codes again. I appreciate the quick response from the members here.
Chicayne is offline
