Turn Signal Problems - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 01-10-2014, 01:00 PM Thread Starter
Does anybody else have problems with their front turn signals. My driver side turn signal lights up when the lights are on but they do not flash when I turn the signal on!!!!
Beezie601 is offline
post #2 of 10 (permalink) Old 01-10-2014, 01:03 PM
What year Cobalt? Do your blinkers hyper flash? Did you try changing the bulbs yet?
post #3 of 10 (permalink) Old 01-10-2014, 02:36 PM Thread Starter
Its an 05 LS I changed the bulbs and still the same problem.
post #4 of 10 (permalink) Old 01-10-2014, 03:42 PM
Does the bulb flash? Or only the dash light?
Flex2.0 is offline
post #5 of 10 (permalink) Old 01-10-2014, 04:33 PM
reaperss06's Avatar
it might be the clicker itself, usually located somewhere underneath the driver side dash.
The other question is, are you sure it's just the front?
Si vis pacem, para bellum
reaperss06 is offline
post #6 of 10 (permalink) Old 01-10-2014, 04:56 PM
Nope, blinkers are controlled by "BCM"
post #7 of 10 (permalink) Old 01-10-2014, 05:14 PM Thread Starter
The back blinker flashes faster than it should like the front blinker is blown
post #8 of 10 (permalink) Old 01-10-2014, 06:17 PM
Did you check if the contacts were still in the socket or if they were clean from corrosion?
post #9 of 10 (permalink) Old 01-10-2014, 06:25 PM Thread Starter
Disconnected and connected several times still the same problem
post #10 of 10 (permalink) Old 01-10-2014, 07:25 PM
It won't work if there is no contacts left inside the socket. Time takes it's toll on an 05 . Sometimes the contacts will weld themselves to the bulb from arcing and heat. When you pull the bulb out , it rips out the connector contacts.
