Help with CEL please. - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 23 (permalink) Old 02-15-2014, 05:49 PM Thread Starter
I have a 2005 Chevy Cobalt LS 2.2L. I regularly get a P0420 code. I have also gotten the following code a few times with the P0420(although not every time):
P0106: Manifold Absolute Pressure (MAP) Sensor Performance - PCM
Also, 2 times in the last 6 months, I have gotten the following code(resulting in "reduced engine power"):
P01681: Control Module Throttle Position (TP) System Performance - PCM
Here are 3 freeze frames(after clearing the CEL and waiting for it to come back on):
Freeze Frame 1:
DTCFRZF() P0420
FUELSYS1() OL
FUELSYS2() --
LOAD_PCT(%) 14.9
ECT(。C) 92
SHRTFT1(%) 0.0
LONGFT1(%) 8.6
MAP(kPa) 37.0
RPM(rpm) 787
VSS(km/h) 0
SPARKADV(。) -1.0
IAT(。C) 11
MAF(g/s) 3.77
TP(%) 24.7
RUNTM(sec) 1331
EVAP_PCT(%) 0.0
FLI(%) 56.9
BARO(kPa) 103
VPWR(V) 13.025
LOAD_ABS(%) 22.0
EQ_RAT () 0.916
TP_R(%) 11.8
AAT(。C) 4
TP_B(%) 24.3
APP_D(%) 17.3
APP_E(%) 9.0
TAC_PCT(%) 15.7
Freeze Frame 2:
DTCFRZF() P0420
FUELSYS1() OL
FUELSYS2() --
LOAD_PCT(%) 14.9
ECT(。C) 91
SHRTFT1(%) 0.0
LONGFT1(%) 7.8
MAP(kPa) 40.0
RPM(rpm) 703
VSS(km/h) 0
SPARKADV(。) -4.0
IAT(。C) 0
MAF(g/s) 3.70
TP(%) 24.7
RUNTM(sec) 1393
EVAP_PCT(%) 0.0
FLI(%) 52.9
BARO(kPa) 101
VPWR(V) 14.599
LOAD_ABS(%) 23.5
EQ_RAT () 0.916
TP_R(%) 11.4
AAT(。C) -1
TP_B(%) 23.9
APP_D(%) 17.3
APP_E(%) 9.0
TAC_PCT(%) 15.3
Freeze Frame 3:
DTCFRZF() P0420
FUELSYS1() OL
FUELSYS2() --
LOAD_PCT(%) 13.3
ECT(。C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 7.0
MAP(kPa) 37.0
RPM(rpm) 700
VSS(km/h) 0
SPARKADV(。) -3.5
IAT(。C) 4
MAF(g/s) 3.29
TP(%) 23.5
RUNTM(sec) 986
EVAP_PCT(%) 0.0
FLI(%) 71.4
BARO(kPa) 99
VPWR(V) 15.183
LOAD_ABS(%) 21.2
EQ_RAT () 0.916
TP_R(%) 10.6
AAT(。C) -3
TP_B(%) 22.7
APP_D(%) 17.3
APP_E(%) 9.4
TAC_PCT(%) 13.7
I am not sure if the P0420 is indeed a problem with the cat, or if it's somehow related to the other problems. I did not start routinely getting the P0420 code until AFTER the very first time I got the P1681. Thanks so much in advance guys.
ChevyTerry is offline
post #2 of 23 (permalink) Old 02-15-2014, 06:23 PM
First off P0242 is not a valid code for a 2005 Cobalt wether boosted or not. What reader are you using?
P0420 can be set by a sudden lack of air intake, for instance hitting a puddle of water and sucking some water into the filter box when temperatures are below freezing. This will cause the water to freeze almost instantly causing air passage restriction. This will force PCM to cut fuel and cause exhaust rich and lean codes. P0420 means cat is inneficient. This might also trick PCM into setting odd codes unrelated. Your 3 freeze frames are all normal. Check your air filter next time for ice or water. Now if you live in southern California disregard all of the above.
post #3 of 23 (permalink) Old 02-15-2014, 06:34 PM Thread Starter
I had not gotten my own code reader until recently. Before that I just stopped at AutoZone, but the guys at my local AutoZone are douche bags. I'm convinced P0242 did not actually occur. I have however confirmed the P1681 with my own code reader, the Autel AL519, which I bought not too long ago. I've removed the reference to P0242 from my OP.
post #4 of 23 (permalink) Old 02-15-2014, 06:45 PM
When was the last time you checked or changed your air filter? Make sure rodents haven't built a nest under the filter.
post #5 of 23 (permalink) Old 02-15-2014, 06:53 PM Thread Starter
Last time it was checked was at Valvoline when I got my last oil change. It was clean.
These P0420s came out of no where. Here I was, had the car 4 years, cars running great, get the P1681, get a few P0106s and start routinely getting the P0420. 6 months goes by, then another P1681 pops up, which was about 2 weeks ago. Now back to the P0420s.
post #6 of 23 (permalink) Old 02-15-2014, 06:56 PM
Where do you live? any road salts applied? Maybe you just need to remove connectors on PCM, spray some cleaner and re-install.
post #7 of 23 (permalink) Old 02-15-2014, 07:04 PM
diagnostics for p1681, say to replace the ecm
short4stuff is offline
post #8 of 23 (permalink) Old 02-15-2014, 07:07 PM Thread Starter
I live in southern Indiana. I don't know if they use road salt around here, but this started last summer, so I'm fairly certain that wouldn't be the problem.
Something just tells me that there's something going on with either the MAP sensor or TPS(which is built into the throttle body) causing a rich condition.
I'm not completely ruling out a bad cat, but I think it would help to know what the typical fuel trim of these cars are. The highest fuel trim from the freeze frames is 8.6, which isn't horrible, but not exactly the best either.
post #9 of 23 (permalink) Old 02-15-2014, 07:12 PM
Does an 8.6 fuel trim not actual mean the engine is running lean. The ecm is trying to add 8.6% fuel... If the trim was -8.6% it would be trying to pull fuel.
post #10 of 23 (permalink) Old 02-15-2014, 07:20 PM Thread Starter
Hmmmmmmmmm, maybe you're right. Shows you how much I know about cars lol. I always thought it was the difference between short term vs long term. Someone educate me lol.
