Trunk Won't Open with Key or Release Button - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 9 (permalink) Old 02-24-2014, 03:41 PM Thread Starter
2006 Chevy Cobalt LS . Trunk release button inside car doesn't work, fuse is fine. Key won't open the trunk either, it won't turn. Any help someone can give would be greatly appreciated.
Also, earlier today, the auto parts store diagnostic scanner came back with link failure. So the cars computer could not link up with his scanner. Any thoughts on what is going on with the car??
FamilyMan is offline
post #2 of 9 (permalink) Old 02-24-2014, 03:55 PM
Check lighter fuse, it powers the OBDII connector. Underhood
post #3 of 9 (permalink) Old 02-24-2014, 04:01 PM Thread Starter
That fuse is fine too.
post #4 of 9 (permalink) Old 02-24-2014, 04:05 PM
OK, ECM fuse underhood also or ECM/TCM fuse BCM fuse block.
post #5 of 9 (permalink) Old 02-24-2014, 05:40 PM Thread Starter
ok I just checked those and they are all good
---------- Post added at 08:40 PM ---------- Previous post was at 07:48 PM ----------
What else could I check?
post #6 of 9 (permalink) Old 02-24-2014, 05:42 PM
Did you pull these fuses out or just checked them with a light?
post #7 of 9 (permalink) Old 02-24-2014, 05:46 PM Thread Starter
Both
post #8 of 9 (permalink) Old 02-24-2014, 05:57 PM
Hmmmm!!!!!
post #9 of 9 (permalink) Old 02-24-2014, 06:37 PM Thread Starter
The trunk lock turned out to be the problem, not fuses or wiring or the release button. Thanks for your suggestions
