Low Speed Steering Chatter - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 03-07-2014, 12:15 PM Thread Starter
I have read the bulletin 04-03-08-006F.
have replaced LCA, Struts and sway bar end links. had alignment performed, and then noticed low speed, rough surface, turn chatter. ( likely was masked before by the shot LCA rear bushings) also alignment included reset of the steering angle, so that it is where it is supposed to be. (steering wheel center aligned with wheels straight)
So does the logic state that if I can reproduce at will, and the vibration/noise still happens with the 60 amp fuse removed, the intermediate shaft should be replaced, and if the fuse out results in no noise, the upper shaft has to be replaced?
looks like the intermediate shaft can be had for under $100, but I cannot see anyplace with the upper assy, which has the motor and the gears. where would this beast come from?
Thanks.
Mike
Free advice is worth what you pay for it (sometimes)
mikeme is offline
post #2 of 12 (permalink) Old 03-07-2014, 07:03 PM
I replaced the lower shaft because of slow speed, rough surface, rattling that sounded like marbles and did not fix my issue :(
This is what mine sounds like.
might watch that vid.
07 G5 GT
Cherry's Tree
Randy
Now serving Boost
272whp 276wtq @10psi
Cherry GT is offline
post #3 of 12 (permalink) Old 03-08-2014, 02:19 AM Thread Starter
I saw that video too, and it is pretty close to what I noticed.
did you pull the fuse and verify that you can hear the rattle with the fuse pulled? (60 A power steering fuse)
or that you cannot hear the rattle with the fuse pulled?
Mike
mikeme is offline
post #4 of 12 (permalink) Old 03-08-2014, 08:40 PM
blazerlow's Avatar
I have what you describe and have assumed it's the intermediate shaft since GM cars are known for that but have never investigated it.
blazerlow is offline
post #5 of 12 (permalink) Old 03-09-2014, 03:31 AM Thread Starter
So how long have you driven with it acting this way? if it is not dangerous, I may just let it go.
Mike
mikeme is offline
post #6 of 12 (permalink) Old 03-09-2014, 05:26 AM
I have not pulled the fuse yet to check,
mine has made this noise for years now.
07 G5 GT
Cherry's Tree
Randy
Now serving Boost
post #7 of 12 (permalink) Old 03-09-2014, 06:32 PM
blazerlow's Avatar
It started out very slight a couple years ago and has progressed to a louder rattle very slowly. I can only hear it on a rough road.
post #8 of 12 (permalink) Old 03-10-2014, 03:24 PM Thread Starter
my DIL ought to be able to deal with it.
(driving to work and back) compared to how much it clunked from bent wheels and shot bushings, it drives like a breeze now.
I was lucky to take it on a slow ride through a closed mcdonalds with shot blacktop and induced the rattle. other than that, just a tap here and there.
thanks for all the feedback.
Mike
mikeme is offline
post #9 of 12 (permalink) Old 04-08-2014, 12:03 PM
AHODA's Avatar
STEERING NOISE ON 06 COBALT - YouTube
IN THIS VIDEO, what is the name of the part that he's replacing?
And what is the TSB#?
CURRENT RIDES
2006 Chevrolet Cobalt LS, (2.2L), 5 speed
1971 Chevy C20 Longhorn (6.6L, 402c.i.BBC)
PAST RIDES
1973 Chevy K20, 4x4, std. cab, longbed (350c.i.);
1979 Chevy Corvette (350c.i.);
2001 Chevy Xtreme S-10, ex-cab, 5spd. (4.3L);
2001 Chevy Silverado 2500HD, 4x4, ex-cab, (6.0L);
2002 Chevy Silverado 1500, ex-cab, 4-6drop (4.8L);
2003 Chevy Silverado 1500, 4x4, std. cab, 5spd (4.8L);
2004 Chevy Colorado Z71, 4x4, crew cab, (3.5L);
2006 HUMMER H3, 4x4, 5spd., (3.5L).
AHODA is offline
post #10 of 12 (permalink) Old 04-08-2014, 12:51 PM
They replaced the steering column in the vid.... the old one is what is in the video, trying to find out the cause of the noise.
07 G5 GT
Cherry's Tree
Randy
Now serving Boost
