No Sunroof Power - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 03-13-2014, 11:46 AM Thread Starter
No Sunroof Power
Hello again everyone,
I can't seem to find anything on here about this yet. My sunroof motor died on me when the switch got stuck in the close position for a few days. So I pulled the motor, ordered a new one, had it arrive 2 months later (yeah...great service.....) and install the new motor. Wired the same, on the same switch (for now) and try it out and nothing. Tested the wires and there is no power what so ever on any of the 4 lines, just 3 neutral and a ground.
The fuse in the kick panel is fine and I don't see one related under the hood. Any ideas? or even a wiring diagram that I could use to rewire the whole thing?
acoutu is offline
post #2 of 10 (permalink) Old 03-13-2014, 12:27 PM
Gm server is loading as we speak.
---------- Post added at 04:18 PM ---------- Previous post was at 04:12 PM ----------
Oops! crashed. Trying again.
---------- Post added at 04:20 PM ---------- Previous post was at 04:18 PM ----------
There we go....
---------- Post added at 04:21 PM ---------- Previous post was at 04:20 PM ----------
What year is your Cobalt again???
---------- Post added at 04:22 PM ---------- Previous post was at 04:21 PM ----------
If you PM me your VIN, I can't get facts pertaining to your car only instead of me searching and guessing.
---------- Post added at 04:27 PM ---------- Previous post was at 04:22 PM ----------
Okay then, green light is on but nobody home.
post #3 of 10 (permalink) Old 03-13-2014, 12:33 PM Thread Starter
05 ls coupe
wiring should be common for all i'd think
---------- Post added at 12:33 PM ---------- Previous post was at 12:31 PM ----------
I'm thinking I'll just rewire the thing to where my window controls are on the door. then I can control everything from there. Hide a smaller switch on the front portion of the arm rest. I just want the damn thing to work first though, the replacement motor cost $300! What a rip off :(
acoutu is offline
post #4 of 10 (permalink) Old 03-13-2014, 12:48 PM
---------- Post added at 04:48 PM ---------- Previous post was at 04:46 PM ----------
Fuse should have blown before motor fried. Are you sure motor was dead?
post #5 of 10 (permalink) Old 03-13-2014, 12:53 PM Thread Starter
Thanks a lot
The old motor would only spin one way so it would only open the sunroof, wouldn't close it.
acoutu is offline
post #6 of 10 (permalink) Old 03-13-2014, 01:19 PM
Are you sure your RAP relay didn't fall out of place or go bad?
---------- Post added at 05:19 PM ---------- Previous post was at 05:03 PM ----------
It's a DC motor. Spin direction depends on voltage polarity at it's pole. I would believe it was your sunroof switch.
post #7 of 10 (permalink) Old 03-13-2014, 01:26 PM Thread Starter
hmmm
RAP is for sure ok as windows and radio still work with it.
The switch was working when I took out the original motor, just got stuck in the full open position. I can't find my old motor now since i no longer have a garage and everything is just tossed in bins, but its slowed down significantly since I bought the car anyways so replacing it wont hurt, just have to figure out the power issues I guess.
My window motors are getting the same way, takes 10-12 seconds to roll them up now. They'll be next to replace once another balt shows up at pick-a-part
acoutu is offline
post #8 of 10 (permalink) Old 03-13-2014, 01:30 PM
Not caused by motors, you have to clean and relube the rails.
post #9 of 10 (permalink) Old 03-13-2014, 04:13 PM Thread Starter
The new motor is dead. I found the power issue when i took the headliner right off (just a loose connection near the back, but the motor wont move....horray.
I'm bringing it back and I'll try fixing the old one when i find it. The rails are working fine, but I'll give them a clean and lube when i re install the old one. I managed to close the sunroof originally but reversing the polarity of the motor, so it seems like only one direction works on it, so it's possible somethings jammed up in it. Oh well, i'll figure it out eventually.
thanks for the help
acoutu is offline
post #10 of 10 (permalink) Old 03-13-2014, 04:37 PM
Originally Posted by acoutu View Post
hmmm
Radio and power window don't work off RAP relay, they work off of a different delay circuit in BCM.
