2006 Cobalt LS Manual Window Stuck - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 03-15-2014, 03:01 PM Thread Starter
Just picked up a base model LS with manual windows.
The drivers side window appears to be jammed. It will not come down (not frozen) as the weather is warm today. I presume the previous owner had this problem for a while as the window lever is stripped and you can feel it just jumping on the shaft as your turn it.
Any common problems I should be aware off before I pop off the door panel?
Thanks in advance!
fierodough is offline
post #2 of 8 (permalink) Old 03-15-2014, 03:17 PM
Can't be too common because I've never heard of a manual crank failing.
post #3 of 8 (permalink) Old 03-15-2014, 03:21 PM Thread Starter
I guess that's a good thing. I guess I will take it apart. I have a feeling it might of jumped the tracks or something. running through the gremlins on this car one at a time.
post #4 of 8 (permalink) Old 03-15-2014, 03:45 PM
swanman35's Avatar
Make sure to post the solution! This will be interesting
swanman35 is offline
post #5 of 8 (permalink) Old 03-24-2014, 02:27 PM Thread Starter
It was the manual window regulator. It was seized and the gears on the had actuator would bind and jump.. I got one from the junk yard for $8.00. I cleaned it out with some solvent and re-greased it. Removing the window clips was a PITA. You need to get the window to come down slightly, press down on both white clips at the same time and push the window regulator rail to the left. Mine was not very cooperative... Once the window was free, I manually lifted it back up and taped it to the door while I installed the replacement regulator.
All good now!
post #6 of 8 (permalink) Old 03-24-2014, 03:30 PM
Iceman62's Avatar
Good deal and thanks for updating us on the fix action. That's the way to save some ca$h...gotta love salvage yards!
MSgt, USAF (Retired)
Iceman62 is offline
post #7 of 8 (permalink) Old 03-24-2014, 04:54 PM
swanman35's Avatar
Cheap fixes are awesome!
post #8 of 8 (permalink) Old 03-24-2014, 05:14 PM
fierodough next time take lots of pictures, we love pictures of Cobalt parts. Often when you see, it is a lot easier to understand.
door , manual , window
