Problem with Fan - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 03-31-2014, 09:47 AM Thread Starter
Problem with Fan
Hey all. First time poster but have been a member for a long time. I looked around and saw some similar threads but nothing exactly like I am experiencing with my cobalt (maybe I missed it I dunno). Wife passed on her 06 cobalt to me when she bought a new car.... everything was fine till about 2 weeks ago. Fan speeds 1-3 have little or no output to them, but 4 works completly normal. I read a thread where someone had a similar instance and someone had mentioned a resistor failing or something to that extent? Anything one else experienced this before?
ibanez122 is offline
post #2 of 12 (permalink) Old 03-31-2014, 12:09 PM
swanman35's Avatar
Well mine acts up too. 3 doesn't work but 1,2 and 4 work. I can feel cold or warm air(wherever the knob is pointed) coming on when it's" off". I was told mine is a switch or something behind the HVAC unit. Someone else will come in and give you a more direct answer though
swanman35 is offline
post #3 of 12 (permalink) Old 03-31-2014, 01:57 PM
Position 4 bypassed the resistor network and Usually never fails. If you have lost 1,2 and 3 chances are it is your resistor network. Easy enough to change at the bottom of the heater box near the blower.
post #4 of 12 (permalink) Old 03-31-2014, 02:33 PM Thread Starter
Thanks for the answer. Any chance you can direct me to a step by step guide on how to fix? Id rather bypass having to take it to the shop and do it myself!
post #5 of 12 (permalink) Old 03-31-2014, 03:30 PM
Sure let me look it up.
---------- Post added at 06:00 PM ---------- Previous post was at 05:54 PM ----------
Check the connector first to make sure it hasn't melted.
You're going to need one of these for starters, ACDelco 1580879
Acdelco 1580879 Blower Motor Resistor | eBay
---------- Post added at 06:15 PM ---------- Previous post was at 06:00 PM ----------
Item number 17 0n here.
---------- Post added at 06:30 PM ---------- Previous post was at 06:15 PM ----------
See same service as Css.net
post #6 of 12 (permalink) Old 04-01-2014, 04:54 AM
Iceman62's Avatar
^^^Yep^^^
Little blower fan relay/board...GM failure rate's high, but pretty simple fix. Get the part and google how to replace. Did my son's 01 Cavalier in ~30-min a few years back.
MSgt, USAF (Retired)
Iceman62 is offline
post #7 of 12 (permalink) Old 04-01-2014, 10:30 AM
beaverG5GT's Avatar
Hello Coby7, I just saw your diagram of the HVAC system and was wondering your thoughts on this noise.
https://www.youtube.com/watch?v=7oXhDsH8FpQ
beaverG5GT is offline
post #8 of 12 (permalink) Old 04-01-2014, 10:57 AM
Sounds like you broke a shaft on one of the trap doors 4,5 and 11 in the picture above. You should never move the knob at the left of the HVAC control before warm air has circulated a bit in the unit to thaw a possible frozen door. You can strip or brake one of the shafts.
post #9 of 12 (permalink) Old 04-01-2014, 12:42 PM
beaverG5GT's Avatar
Thanks. That's probably what i have done. The sound is louder when the weather is warmer. It will flap away like that and sometimes there will be a louder flap noise like it slams shut. Then it stops for a while.
I am thinking the trap doors then are hinged on both sides, and one side might be broken.
Easy fix? Lots of work to get to it i bet.
post #10 of 12 (permalink) Old 09-03-2014, 10:29 AM
beaverG5GT's Avatar
Just got around to taking my dashboard out to try and find the flap flap noise. From what i read, i was expecting worse. It turned out to be foam. Took it out and all functions fine. I thought it might effect the air, but i don't notice any difference. I now have air out both center vents again!.
