'08 Cobalt Coolant? Problem - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 04-03-2014, 06:39 PM Thread Starter
Hey folks, been awhile. The other day wife is driving home from work, AC stops cooling all of a sudden, AC dash lights stayed on, just air got warm. Next day driving to work, "engine" light is on, she scrolled through info, coolant reads nothing. Her boss checked under the hood, sees coolant reservoir is low, adds about a cup he says of coolant, later I find out this was 50/50 GREEN.(EG) I drained the system today & poured through distilled water, then closed & filled eith 50/50 DEXCOOL. Ran the motor & heat/defrost for awhile thinking the engine would suck it in at some point & I could top off reservoir. After about 45 minutes or more, I gave up, reservoir never droped & hose was just a little warm. Radiator fan ran the entire time, I thought it was supposed to go on & off, never stopped. Sorry if I is ignant, just trying to keep the work vehicle running? Any thoughts from the Cobalt pros? TIA
45auto is offline
post #2 of 15 (permalink) Old 04-03-2014, 07:16 PM
Whats the code for? Its either your thermostat or your temp sensor. Both cheap and easy fixes
post #3 of 15 (permalink) Old 04-04-2014, 08:42 PM Thread Starter
Code is P0128, says thermostat, is that definitely it? Shows dashes in "---" in coolant display (DIC). Thanks for the thoughts BB.
45auto is offline
post #4 of 15 (permalink) Old 04-05-2014, 08:05 AM
Replace thermo and temp sensor
post #5 of 15 (permalink) Old 04-05-2014, 08:54 AM
Check the connection to the temperature sensor first. Chances are thermostat is still good.
post #6 of 15 (permalink) Old 04-05-2014, 10:47 AM Thread Starter
Believe you're right C7, replaced thermostat, no change. Going to replace sensor now. Would sensor make radiator fan run when starting the engine?
45auto is offline
post #7 of 15 (permalink) Old 04-05-2014, 11:00 AM
Yes it is a caution measure the car takes when it doesnt know how warm it is
post #8 of 15 (permalink) Old 04-05-2014, 01:28 PM Thread Starter
Well, after install of coolant temp sensor, ran the engine for awhile with defrost, DIC coolant temp started working, & AC cooled again.(YEA!) Took it for an extended test drive on city streets & the freeway, temp never exceeded 199f with defrost on. Seems to be ok. Tried to clear codes to turn off engine light, but is still on. Will if go off by itself?
45auto is offline
post #9 of 15 (permalink) Old 04-05-2014, 01:59 PM
Could be another code. Did you actually use a scanner to delete?
post #10 of 15 (permalink) Old 04-05-2014, 02:09 PM Thread Starter
used an sct mustang tuner. Went ahead * checked for codes again, now shows P0128 & P0118...
45auto is offline
