Brake Light Switch - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 04-13-2014, 03:24 PM Thread Starter
09cobalt 2.2's Avatar
Brake Light Switch
the brake lights on my 09 ls coupe 2.2 will not work all the fuses are good is there any way to test the brake light switch or bcm (hope its not the bcm) any help? thanks
09cobalt 2.2 is offline
post #2 of 15 (permalink) Old 04-13-2014, 04:10 PM
Hope your bulbs are good.
---------- Post added at 08:10 PM ---------- Previous post was at 08:08 PM ----------
Do your blinkers work?
post #3 of 15 (permalink) Old 04-13-2014, 05:19 PM Thread Starter
I got ipcw aftermarket tail lights and yes all the lights work but the brake lights. Yesterday the brake lights stayed on even when the brake was not pressed. And it took more pressure to let me get the car out of park. I took the senser off and when I turn the key on I can move the shifter without the senser connected
post #4 of 15 (permalink) Old 04-13-2014, 06:37 PM
Without starting the turn key to "ON" press brake pedal. High brake light should come on it isn't fed by BCM. Blinkers and stop lamps use the same wiring straight from BCM, so if blinkers work so should the brakes.
post #5 of 15 (permalink) Old 04-13-2014, 08:07 PM Thread Starter
Then it would be the switch because the blinkers work but the brake lights don't. The high brake light doesn't work either
post #6 of 15 (permalink) Old 04-15-2014, 11:07 AM Thread Starter
Well I got my new switch and still nothing all fuses are good all lights work but brake so pissed
post #7 of 15 (permalink) Old 04-15-2014, 01:27 PM
swanman35's Avatar
Hmm maybe wirinf in the light?;
swanman35 is offline
post #8 of 15 (permalink) Old 04-15-2014, 06:05 PM Thread Starter
It can't be the turn signals run off the brake system
post #9 of 15 (permalink) Old 04-15-2014, 06:37 PM
Check if the BCM is receiving the brake pedal signal. P2 pin 31 it will be a yellow wire.
post #10 of 15 (permalink) Old 04-15-2014, 08:04 PM Thread Starter
Will check tomorrow I was thinking the same thing
