P2138 - How To? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 05-07-2014, 06:20 PM Thread Starter
P2138 - How To?
'06 Colbalt LT.
Driving today, check engine light, reduced engine power and T/C turns off. Made it home, scan for codes - P2138. Got this about a month ago as well (along with P2128 ). Digging around online, seems like the likely culprits are accelerator pedal position sensor, loose wire someplace, or there are two TSBs I think, a leak in Pillar A that may leak on a connection, and checking the PCM build dates as some were faulty.
Any other posibilities that need to be considered? I've learned the PCM code is not suspect (had that checked out last time the code came up) and code popped today when it was sunny and 60, hasn't rained in 3 days and has been driven 90 miles prior to getting the code. Thinking I should have the APP sensor taken care of?
Is this a difficult replacement? Anyone have a how to or could give me a walk through?
TIA.
2006 Cobalt LT
jcapartmentsale is offline
post #2 of 12 (permalink) Old 05-07-2014, 07:21 PM
APP sensor is simple to change, one connector and 3 screws. It only fits one way.
post #3 of 12 (permalink) Old 05-08-2014, 06:13 AM Thread Starter
Probably a dumb question but is the sensor behind the gas pedal, or is it behind (in) the side panel? Directions seemed more complicated in the repair manual excerpt I found.
2006 Cobalt LT
post #4 of 12 (permalink) Old 05-08-2014, 09:07 AM
Yeah, it's right on the pedal. I thought it only had 2 screws and a line-up pin but it has 3 screws that holds it in place.
post #5 of 12 (permalink) Old 05-24-2014, 12:48 PM Thread Starter
Coby7 - thanks again, after doing it myself, I saw it was much ado about nothing. As you said 3 bolts, tight squeeze but very simple. Hopefully this solves the issue.
2006 Cobalt LT
post #6 of 12 (permalink) Old 05-24-2014, 03:27 PM
You should post a picture of the old one pulled so people on here know what it looks like. We love pictures you know...
post #7 of 12 (permalink) Old 05-24-2014, 06:32 PM Thread Starter
Not the greatest pics but this should give a good idea of what it looks like.
Whole part:
Electrical Connection:
Side view (can see where the 3 bolts would be):
2006 Cobalt LT
post #8 of 12 (permalink) Old 06-19-2014, 04:14 PM Thread Starter
Soooo... as it turns out not the AAP sensor (or at least I still have the same problem/symptoms) . A little over 400 miles since I changed the pedal out. Leaving work. boom, check engine, reduced power. Pulled back around into the parking lot, turned the car off, pulled the same code - P2138. Waited 30 seconds and turned the car over. Engine power back and drove home no issues.
I'd seen what I think is a TSB for a leak in pillar A that indicates possible code of P2138 but the last two times the code has popped it's been a warm/hot sunny day with not much rain previously.
Any other ideas?
2006 Cobalt LT
post #9 of 12 (permalink) Old 06-20-2014, 03:51 AM
tred07's Avatar
i changed my throttle body after no luck switching out new gas peddle assembly.fixed my problem
tred07 is offline
post #10 of 12 (permalink) Old 06-20-2014, 03:52 AM Thread Starter
tred07 - Same code?
2006 Cobalt LT
