2005 Cobalt Transmission Help Needed? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 04-20-2016, 12:09 PM Thread Starter
Hello gang, just found this site, and am in need of some help. I have a 2005 Cobalt, with an automatic trans. 107,000 miles. Car has shown NO trans problems whatsoever before the issue described next. Wife was sitting at a red light the other day, and when she went to take off, the car gets to around 40 MPH, the trans will not not shift, just revs up. There are NO codes showing up whatsoever. No check engine light at all. I tried the TCM fuse and it is fine. I disconnected the battery, and problem persists. Car seems to have no other issues. Anyone else ever have this issue? Any suggestions? Thanks in advance! - Drue
dl4jesus is offline
post #2 of 6 (permalink) Old 04-20-2016, 12:42 PM
If you don't have a check engine light you may still have history codes or pending codes. Is anything else acting up? Maybe re-seat the BCM connectors and change the PCM/TCM fuse on the BCM fuse block. It might be pitted or corroded.
post #3 of 6 (permalink) Old 04-26-2016, 08:53 AM
OCBaltBabe's Avatar
My balt has been having this issue. 05. Around the same milage 106XXX I never found out exactly what's doing it. My balt only does it when its cold. I tell her she's temperamental. I'm from northern Indiana so were coming into warmer weather and it practically stopped. Just early morning drives or late nights after it hasn't been driven a while. I'll be following to see if you find out for sure.
OCBaltBabe is offline
post #4 of 6 (permalink) Old 05-02-2016, 05:03 PM
My daughter has 09 LT with 83,000 miles that had a spontaneous problem a couple months ago - out of the blue it started slipping, you had to gently accelerate but at 40+ it was fine. Had a local shop diagnose. Could not find a bad valve or actuator (?) or any code.
Basically options were pull it out and have it rebuilt or replace with used. In order to get it resolved quickly went with used (50,000 miles) trans from recycler with 1 yr warranty.
Bottom line $1400 and back end of next day with no problems except resetting clock and date. (But still had radio presets!). At the same time I got a shifter for $50 and had it changed out because red tab that indicates gear position had broken a while back.
A couple months of regular use with no regrets. (There was an option for used trans with 30K for $1700 installed, but either way tranny has less than the car.
jimtcd is offline
post #5 of 6 (permalink) Old 05-05-2016, 11:26 AM
hi . you need to change transmission fluid and filter . if you have bad automatic transmission try lucas fix
ayadiala is offline
post #6 of 6 (permalink) Old 06-16-2016, 06:57 PM
Transmission maintenance for me includes:
Auto-Rx to liquify any gumny deposits
Xado revitalizant to repair-in-place wearing of metalic contact points/surfaces
Just turned 445K on a 2.2l 2007 Pontiac G5 sedan with A/C, power windows but not the front frog lights. And I do mean frog lights.
Good luck in your situation. Stay positive and look for solutions!
kanaloa is offline
