07 Engine in an 06 Cobalt - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 02-04-2017, 04:46 AM Thread Starter
Hello,
I will try to be as thorough as possible with my description. I blew a rod in my 06 engine and it shot through the block so I needed to do an engine swap. found a good deal on an 07 engine but didn't realize that the slight difference in the 07 engine thought it would be a simple swap but after the swap the car is not turning over.
I am using the harnessing wire from the old engine, i am using all of the 06 components, ICM /coil strip, crankshaft sensor. throttle body. I am at not sure what else could be causing this issue. Any guidance would be helpful if anyone has done this before.
Theoli is offline
post #2 of 7 (permalink) Old 04-10-2017, 06:18 PM
Originally Posted by Theoli View Post
Hello,
Between 06 and 07 they changed everything. Sensors, cams, even the block
Sent from my SM-G900V using Tapatalk
rachuy.cody is offline
post #3 of 7 (permalink) Old 04-16-2017, 02:02 PM
You should not have even been able to plug in the crankshaft position sensor. How did you? in 2007 the 2.2 Ecotec went to a reluctor or interrupt ring on crankshaft. So the sensor is now a 3 wire and without is communication to ECM, the fuel pump will not pressurize as well as many other issues.
uluz2a6 is offline
post #4 of 7 (permalink) Old 04-16-2017, 02:41 PM
Plus reluctor ring has a different number of teeth. So You'd have to swap the crank for it to work.
post #5 of 7 (permalink) Old 07-22-2017, 09:19 PM
Where do I look to find out what trany I have in my 06 cobalt
Sent from my SM-G920V using Tapatalk
post #6 of 7 (permalink) Old 07-23-2017, 04:51 AM
RPO list in trunk under mat to the left of the spare tire.
post #7 of 7 (permalink) Old 07-25-2017, 11:05 AM
Automatic Cobalts have the 4T45e tranmission.
stower17 is offline
