P0013/P0014 Light Still on After CMP Actuator Solenoid Valve Change - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 4 (permalink) Old 08-20-2017, 05:13 PM Thread Starter
Cobalt 2009 LS, 50K miles.
The check engine light comes and goes, sometimes P0013, sometimes P0014 and sometimes both.
Have done the followings:
1. Changed oil (SAE 5W 30);
2. Replaced the exhaust Camshaft Position Actuator Solenoid Valve (Genuine GM part #12655421);
3. Checked the CMP actuator solenoid connector & measured the resistance across the two pins. The new exhaust one reads 12.2 ohms and the old intake one reads 13 ohms.
But the light is still coming on, after 2 30-minutes driving.
What should I be checking next?
Thanks!
kevin_ivy is offline
post #2 of 4 (permalink) Old 08-21-2017, 03:30 AM
Follow those wires and check for frayed jacket. It might be touching ground somewhere. You may need and other armor loom along the back side of the valve cover just above the exhaust manifold.
post #3 of 4 (permalink) Old 08-21-2017, 07:53 AM Thread Starter
Thanks a lot! I will do what you have said. The final way is to go to a garage or buy a powerful scan software.
post #4 of 4 (permalink) Old 08-27-2017, 09:27 AM Thread Starter
The check engine light eventually turned off and didn't come back after 500km.
Also, Coby7, Thank you!
