2010 Chevy cobalt no start - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 08-21-2017, 07:43 AM Thread Starter
I have a 2.2 in it that I have recently replaced the timing chain on. I also did the head in order to check the valves. I got it all put back together and now it won't start. Cranks good but won't fire up. I have spark and fuel pressure. I am sure I got the timing lined up correctly. It said engine power reduced before I cleared the codes. I have cam solenoid codes but that was caused from metal shavings in the oil and shouldn't affect startup? I also cleaned them. I don't know why it won't fire. I have read a lot about the crankshaft position sensor but I have no codes indicating that. I am tight on cash after the repair and need to get this figured out without slapping tons of parts on. Is there a reason I need a high end scanner to get it running?
Matt Burt is offline
post #2 of 3 (permalink) Old 08-21-2017, 08:11 AM
You could ohm the crankshaft position sensor. It's worth a shot. You couo d also check compression to see if the timing is correct.
Charlie Gates is offline
post #3 of 3 (permalink) Old 08-21-2017, 08:15 AM Thread Starter
I am going to ohm it right now. Also I believe compression is fine but I will test. Could I have been on the wrong stroke when aligning the timing? It's not something I took into consideration beforehand. Also it's throwing a P0010. Would a cam sensor or solenoid keep it from starting?
