2010 Will Crank but Not Turn Over. - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 12-10-2017, 03:17 PM Thread Starter
Being of last month had new timing chain , spark plugs, oil change and Radiator flush done to car.
Starting and running fine. Then few days ago get out of store will not turn over. Read codes P0013 pops up replace
get it to crank but not start. New codes P0016 and P0017 cranks will not start clear codes, they came back.
Have spark and gas, will crank but not to full start. any idea please. lost and do not have time to keep adding more parts. Thank you!
RDLynn is offline
post #2 of 5 (permalink) Old 12-10-2017, 06:46 PM
Sounds like you lost the crank position sensor to me, check connection. But can't be sure because I'm way over here.
post #3 of 5 (permalink) Old 12-11-2017, 05:29 AM Thread Starter
I apologize for misunderstanding,(P0016andP0017) CKP intake an exhaust were both replaced. Fuses were checked. Tries to start but will not fully turn over.
RDLynn is offline
post #4 of 5 (permalink) Old 12-11-2017, 11:14 AM
Cam actuator is not the crank position sensor. If you are having crank to cam correlation errors you will not have ignition at the proper time, therefore no start. The crank sensor is at the bottom of the block near one end of the crank.
post #5 of 5 (permalink) Old 12-11-2017, 06:20 PM Thread Starter
Thank you so much Coby7 . Had to charge battery, other codes cleared. Did a new reading it came up p0341. But I am definitely checking the crank shaft sensor. Looking at it found a yellow purple Twisted wire passenger side on the back of engine passenger side. that seems to be loose or not connecting correctly. Was not secured down when timing chain was done last month. No I did not do timing chain myself, to small for that.
RDLynn is offline
