Coolant Check - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 12-27-2017, 05:09 PM Thread Starter
Coolant Check
Okay don't laugh but it is getting pretty cold here this year and I need to know how to check my coolant. I have a 2006 coupe. I know it says just look at the level in the overflow reservoir to see if it is at correct level. But I am just not comfortable with that and it does look a little low and is not as orange as it once was. The problem is there is some kind of filter blocking me from using a regular antifreeze tester and it is not removable. As I said don't laugh because I am just a woman after all I can't be expected to know these things.
kaykaye64 is offline
post #2 of 3 (permalink) Old 12-27-2017, 07:30 PM
Why do you need to check the coolant level? Is the car running hot?
On the coolant overflow reservoir, it should give you a line to look for - and whether that line is to be read while the coolant is hot or cold. It can get a little harder as the plastic yellows, though.
MP81 is offline
post #3 of 3 (permalink) Old 01-01-2018, 11:06 AM
Here is a non smart guy answer. I wanted to do the same to my daughters 06 Cobalt. So i took a pair of needle nose pliers and broke off a piece of the filter you are talking about. Mine stayed in the pliers. I then took a small straight blade screwdriver and pushed a piece away. I could then check the freeze point of the coolant.
redsled is offline
