Inside Tire Wear / Rattle / Drift - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 10-10-2013, 05:57 AM Thread Starter
I have attached a picture of my drivers side front tire. It has excessive wear to the inside. In fact, the belt is starting to show.
The car tends to drift when driving and seems much worse when there is moderate wind.
Finally, there is a rattle/grind sound when turning at slow speeds. I also hear it when I hit a bump.
I pulled the wheel and couldn't find anything loose. The other three tires are not affected. Any ideas?
[IMG][/IMG]
Hogpaw is offline
post #2 of 15 (permalink) Old 10-10-2013, 07:09 AM
What's an alignment rack tell you?
I'd be leaning towards something like...tie rods, hub assemblies...could be an alignment it needs in general...
Lots of possibilities.
bluegtp91 is offline
post #3 of 15 (permalink) Old 10-10-2013, 07:25 AM
Outer tie-rod end!
post #4 of 15 (permalink) Old 10-10-2013, 07:40 AM Thread Starter
I replaced the outer tie rod end with (Moog ES800030 Tie Rod End) on January 18th, 2013. I have driven 11264 miles since I replaced them.
Possibly defective?
---------- Post added at 09:40 AM ---------- Previous post was at 09:39 AM ----------
I have a 1:00 appointment to have the alignment checked.
Hogpaw is offline
post #5 of 15 (permalink) Old 10-10-2013, 07:58 AM
If tie-rods are good you have excessive toe-out
post #6 of 15 (permalink) Old 10-10-2013, 08:06 AM
Likes I saids.
Alignment.
You can replace suspension parts without one...hence why I like to do them all at once so I only have to get it aligned once, lol.
post #7 of 15 (permalink) Old 10-10-2013, 08:06 AM Thread Starter
Could that cause the car to drift on the freeway?
Hogpaw is offline
post #8 of 15 (permalink) Old 10-10-2013, 08:21 AM
Yep, definitely
---------- Post added at 12:21 PM ---------- Previous post was at 12:20 PM ----------
And I think you need 2 new front tires.
post #9 of 15 (permalink) Old 10-10-2013, 08:30 AM
Ditto on the tires.
Would make sure they're all in balance and the rims aren't bent either.
post #10 of 15 (permalink) Old 10-10-2013, 09:14 AM Thread Starter
The rest of the tires have great tread. I am going to replace this one.
Hogpaw is offline
