You should get YYZ's. But if that's beyond your budget, you should buy my used Sportlines. I'll make you a sweet deal
Black 2010 SS/TC – G85 | ZFR6758 | Term2 tuned | 479whp, 470wtq | Built internals | Cryo'd 4.45 | CM S4 clutch | Hahn CP | ZZP IC | Forge BPV | Hahn 3” DP and Catback | Hahn CAI | Ported head & intake | LE5 TB | Opel injectors + custom 5th injector | ZZP S3 cams | 82# valve springs | 420lph E85 LPFP | Custom FM oil cooler | PRS YYZ v3 & Koni yellows | PRS XXX bar | PRS rotated mounts, rear bushings & TCABS | PRS PCV | PRS Racing oil pan | PRS brake ducts
