Rear End Clunk - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 11-27-2013, 11:10 AM Thread Starter
Rear End Clunk
My son has a 2006 LS 4door with 90k miles. When we bought it, we had a clunking in the rear when going over bumps.
We replaced the rear shocks, checked the spare tire hold down and even replaced the tires.
Exhaust system was and ss all tight.
It seemed like it got better, but he just came home from college and I drove it and it seemed as bad as it had been before all of the work we did.
What is the most common problem of a loud clunking in the rear end when you go over bumps.
glava2876 is offline
post #2 of 5 (permalink) Old 11-27-2013, 12:18 PM
The most common is broken springs, second most common is shock bolts coming loose because they weren't torqued properly.
post #3 of 5 (permalink) Old 11-27-2013, 12:27 PM Thread Starter
Thanks Coby7. It was the shock bolt, but it was because when I torqued it the lower one had enough rust that even after PB Blaster it must have been binding.
I tightened it more and that was it!
post #4 of 5 (permalink) Old 11-27-2013, 12:44 PM
Tighten
• Tighten the upper bolt to 90 Nm (66 lb ft).
• Tighten the lower bolt to 110 Nm (81 lb ft).
---------- Post added at 03:44 PM ---------- Previous post was at 03:42 PM ----------
Don't ask me why the top bolts is torque at less force than the bottom. Makes no sense to me but that's right out of the GM server service manual.
post #5 of 5 (permalink) Old 11-27-2013, 12:56 PM Thread Starter
Tighten
Thanks again!
