Upgrade to FE5... Other Parts Needed? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 16 (permalink) Old 12-03-2013, 05:19 PM Thread Starter
EvolveCobaltSS's Avatar
Hi every one,
I have an 06 Cobalt SS 2.4. I will buy the FE5-S Shocks and struts package from CED. I heard that it was a good idea to upgrade the end links.
1) Is that true?
2) If yes, what year do I need? There is a 2005-2007 part and 2008-2010 one. Do I need the 2008-2010 because I install the suspension from those years?
3) Do I need two end links? (1 left and 1 right)
It is the first time I upgrade the suspension on a vehicle, and I don't really understand how it works. Thanks a lot
EvolveCobaltSS is offline
post #2 of 16 (permalink) Old 12-03-2013, 05:56 PM
To answer your questions:
1) Yes.
2) '05-'07 is good, '08-'10 is better. Yes.
3) Yes. Moogs are recommended.
You might also want to consider upgrading springs and/or sway bars. There are great write-ups on the subject that I highly suggest you read up on.
https://www.yourcobalt.com/forums/sus...aq-advice.html
https://www.yourcobalt.com/forums/sus...rade-list.html
Happy modding.
post #3 of 16 (permalink) Old 12-03-2013, 05:58 PM
k750012 is the part number for the endlinks that you're gonna want. yes you'll need two of them
post #4 of 16 (permalink) Old 12-03-2013, 07:16 PM
You don't have the FE5 front swaybar so you want the longer endlinks 11.xx vs 9.xx it doesn't matter which years, it'll be the 2.2 ones from 05-10 none of the FE5 endlinks will work. What you want from 08-10 is the FE5 shocks/struts and springs, they were redisigned and improved from the SS/SC to the much better SS/TC stock setup.
post #5 of 16 (permalink) Old 12-03-2013, 08:40 PM
They will work, they will just move the sway bar up, giving it a more stirdy feel
post #6 of 16 (permalink) Old 12-04-2013, 07:42 AM Thread Starter
Thanks a lot for all your answers So, just to make sure that I have understood everything.
With the FE5-S package, it's recommended to buy 2 of these parts
MOOG-K750012 MOOG Front Sway Bar Endlink Kit - Naturally Aspirated - 9.86 Inch Center to Center
Also, I forgot to say that I will add Eibach Sportline springs to this setup.
Is that a good setup? Thanks
post #7 of 16 (permalink) Old 12-04-2013, 07:50 AM
Eibach sucks. Get ssc or h&r
---------- Post added at 09:50 AM ---------- Previous post was at 09:48 AM ----------
Also, there are cheaper places for those endlinks
post #8 of 16 (permalink) Old 12-04-2013, 09:05 AM
Do you want low or handling foremost?
YYZ is the best for handling, SSC is a nice mix of low and handling, H&R is a great set of springs for just low, probably an improvement vs FE1 but when you lose that much suspension travel it's not going to handle as good as a car with springs designed for handling foremost like YYZ's are.
Here's how my car sits on YYZ V.3 springs
post #9 of 16 (permalink) Old 12-04-2013, 10:53 AM
good info
custom 68 is offline
post #10 of 16 (permalink) Old 12-19-2013, 01:42 AM
Going to be picking up a pair of Moog endlinks myself. I have FE5 shocks (08-10) and the stock L61 swaybar, although I will eventually upgrade to the SS/TC bar. Am I looking for the 9'' or the 11''?
