Are Tire Chains OK to Use? Or Must I Run Cables. - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 12-06-2013, 09:57 AM Thread Starter
AHODA's Avatar
Hey guys,
A large storm is coming in tonight, and I live in the CA mountains, so I need chains/cables, as required by law. I have some chains that I can cut-down (they are too long) that I'd like to use to save $$$.
However, I remember a while back when I went to purchase chains for another vehicle I was told that- some vehicles shouldn't use tire chains only tire cables. Something to do with manufacture recommendations.
So I do not have the owners manual to check if it's ok to use chains. Does anybody know what Chevrolet says regarding this?
I am running the recommended 195/60/15 tire size and have not modified the suspension.
CURRENT RIDES
2006 Chevrolet Cobalt LS, (2.2L), 5 speed
1971 Chevy C20 Longhorn (6.6L, 402c.i.BBC)
PAST RIDES
1973 Chevy K20, 4x4, std. cab, longbed (350c.i.);
1979 Chevy Corvette (350c.i.);
2001 Chevy Xtreme S-10, ex-cab, 5spd. (4.3L);
2001 Chevy Silverado 2500HD, 4x4, ex-cab, (6.0L);
2002 Chevy Silverado 1500, ex-cab, 4-6drop (4.8L);
2003 Chevy Silverado 1500, 4x4, std. cab, 5spd (4.8L);
2004 Chevy Colorado Z71, 4x4, crew cab, (3.5L);
2006 HUMMER H3, 4x4, 5spd., (3.5L).
AHODA is offline
post #2 of 6 (permalink) Old 12-06-2013, 10:04 AM
Tire Chains
Caution: If your vehicle has P195/65R15, P205/55R16, P205/50R17, or 225/40R18 size tires, do not use tire chains. They can damage your vehicle because there is not enough clearance.
Tire chains used on a vehicle without the proper amount of clearance can cause damage to the brakes, suspension, or other vehicle parts. The area damaged by the tire chains could cause you to lose control of your vehicle and you or others may be injured in a crash.
Use another type of traction device only if its manufacturer recommends it for use on your vehicle and tire size combination, and road conditions. Follow that manufacturer's instructions. To help avoid damage to your vehicle, drive slowly, readjust, or remove the device if it is contacting your vehicle, and do not spin your vehicle's wheels.
If you do find traction devices that will fit, install them on the front tires.
Notice: If your vehicle has a tire size other than P195/65R15, P205/55R16, P205/50R17 or 225/40R18 size tires, use tire chains only where legal and only when you must. Use only SAE Class S-type chains that are the proper size for your tires. Install them on the front tires and tighten them as tightly as possible with the ends securely fastened. Drive slowly and follow the chain manufacturer's instructions. If you can hear the chains contacting your vehicle, stop and retighten them. If the contact continues, slow down until it stops. Driving too fast or spinning the wheels with chains on will damage your vehicle.
post #3 of 6 (permalink) Old 12-06-2013, 10:44 AM
They MAKE you wear chains? man i want to live there with that amount of snow.
Mkulrey13 is offline
post #4 of 6 (permalink) Old 12-06-2013, 11:26 AM
Cables are the only way to fly.....
Ridinonrails is offline
post #5 of 6 (permalink) Old 12-06-2013, 03:31 PM Thread Starter
AHODA's Avatar
Thanks Coby7.
That is exactly what I needed to know. The chains I have are S.A.E. "S" and my tires' are small enough.
---------- Post added at 02:31 PM ---------- Previous post was at 02:24 PM ----------
If you are driving where there's snow in a 2wd w/out chains you have a pretty good chance at a ticket (especially if you get stuck). Also if pulled over in good weather, in snow country, with/out possessing chains/cables you could get a big fine.
But, it's nice living where you have the possibility of getting a-lot of snow overnight...
CURRENT RIDES
PAST RIDES
AHODA is offline
post #6 of 6 (permalink) Old 12-06-2013, 04:25 PM
Pssh. Colorado never requires chains for cars, only semis. But then again the people that live in the resorts have serious snow tires...
colodude18 is offline
