Zzp Rotated Mounts - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 12-19-2013, 03:01 PM Thread Starter
Zzp Rotated Mounts
I got rotated mounts front and rear also a new motor mount. Is their a specific way to install rotated mounts or just remove old install new
derekhollister is offline
post #2 of 12 (permalink) Old 12-19-2013, 03:28 PM
Remove and install
post #3 of 12 (permalink) Old 12-19-2013, 04:09 PM
Just remove and install. ZZP's so called rotated mounts are really just stiffer mounts in the factory location so you only have to support the engine not change it's position like real rotated mounts. Why anyone buys these mounts are beyond me, I'd return them and get Powell's mounts which are actually rotated and high quality for a comparable price.
post #4 of 12 (permalink) Old 12-19-2013, 04:13 PM Thread Starter
No powells are expensive
post #5 of 12 (permalink) Old 12-19-2013, 04:37 PM
As with most things, you get what you pay for.
post #6 of 12 (permalink) Old 12-19-2013, 04:38 PM Thread Starter
That's ok
post #7 of 12 (permalink) Old 12-19-2013, 04:48 PM
Hey, they're better than stock, so you might aswell install them.
post #8 of 12 (permalink) Old 12-19-2013, 05:46 PM
So it's $10 more for Powell's mount front mount which is actually rotated and if it's an LNF theirs no point in getting the rear mount since it's already stiffer so it seems to me like Powell's mount is cheaper while being better...
post #9 of 12 (permalink) Old 12-20-2013, 06:36 AM
^^This. The main reason to change out the mounts is to rotate the engine. The stock lnf mounts are plenty stiff. I'm a big ZZP fan myself, but in most cases if Powell sells the same part, his is better at a comparable price.
Originally Posted by John Powell
The principle behind the mounts is to rotate the motor up at the back, down at the front, to move the axle output shafts in better alignment with the axle output flange at the knuckle. The rotation was developed and engineered with help from GM, when I was under contract to produce Cobalt road race cars in 2004/2005
colodude18 is offline
post #10 of 12 (permalink) Old 12-21-2013, 06:36 AM
Yea zzp mounts r not rotated
C_A_D88 is offline
