Lower Control Arm Bolt - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 27 (permalink) Old 01-08-2014, 02:04 AM Thread Starter
I'm replacing my passenger side control arm. When I got to the main large bolt in the back, I started loosening it but it won't come out. It just keeps spinning. Wtf? Lol
Slobalt 07 is offline
post #2 of 27 (permalink) Old 01-08-2014, 05:45 AM
Its a looooooooong bolt. Just keep spinning
post #3 of 27 (permalink) Old 01-08-2014, 05:48 AM
Batmobile's Avatar
That's what she said :D
Batmobile is offline
post #4 of 27 (permalink) Old 01-08-2014, 06:59 AM
You need to drop the sub frame, only easy solution. Take out the space to go to the link between ss and .net
http://www.cobaltss .net/forums/suspension-67/powells-take-replacing-bad-control-arm-bushings-301627/
I had mine replaced with Powell's CAB's and I was lucky that the bolt came right out (actually did it in Powell's garage, so mainly he did it).
post #5 of 27 (permalink) Old 01-08-2014, 07:20 AM
You do not need to drop the whole subframe. Ive done this job probably 7 times now and ive never had to remove anymore bolts than the vertical, 2 horizontal and the ball joint to remove and replace this thing.
post #6 of 27 (permalink) Old 01-08-2014, 09:01 AM
We're probably not talking about the same bolt then. Did you look at the link banker? I know a local that had to drop the subframe to get that same bolt out. Or you haven't had one get stuck and break on you.
post #7 of 27 (permalink) Old 01-08-2014, 09:25 AM
Same bolt. I guess ive just used enough heat and lube to get it out every time
post #8 of 27 (permalink) Old 01-08-2014, 09:35 AM
Powell uses the same thing but only once the entire subframe is out and easier to work on. Something with using heat there not being recommended.
post #9 of 27 (permalink) Old 01-08-2014, 09:38 AM
I have fe5 control arms and powell cabs. I only put heat on the head of the bolt if needed. Never had to drop the subframe. Ive bent it down before to get the control arm out and in, but never removed subframe for it
post #10 of 27 (permalink) Old 01-08-2014, 09:40 AM
I'm not saying your wrong I'm just telling him what Powell recommends and giving him a link to the issue. I have that exact same setup for control arms, T CABS Trailing and L CABS Leading. With where they are you could potentially damage other parts by using heat (his specific example was the old bushing starting on fire).
