Great Article on Turning Rotors and Nondirectional Finishes - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 1 (permalink) Old 02-05-2014, 07:06 PM Thread Starter
This is an absolute gem I came across on brakeandfrontend.com. It is a bit technical, more for someone working with machining equipment, but it's a good read if that's your thing (I'm like a sponge). It reads as follows:
You have probably heard that nondirectional rotor finishes can lessen the risk of new brake pads squealing. They can, but do you really need to apply a nondirectional finish to freshly turned rotors. And what about new rotors? Should you give them a nondirectional finish if they don’t have one? Like many issues concerning brake rotors, different people have different opinions about what works best. So with that said, let’s take a closer look at rotor refinishing and what it really takes to guarantee quiet brakes.
WHEN TO TURN ROTORS
By the time a vehicle needs new brake pads, the rotors may show considerable wear. The areas on the rotors where the pads rub will often have grooves, maybe some minor surface cracking or pitting, and possibly enough variations in thickness due to wear that are causing noticeable pedal vibrations when the brakes are applied.
Most shops resurface rotors every time they replace a set of pads. Some would argue that rotors in relatively good condition (only minor grooving and no hard spots, cracks or pedal pulsations), do not need to be resurfaced. Not resurfacing the rotors extends their life and saves the vehicle owner some money. Others say the risk of a comeback because the rotors were not resurfaced is reason enough to turn the rotors. Do the job once and do it right the first time is their reasoning.
If the rotors are cracked or have hard spots, most experts agree that replacement is the only option — and certainly if the rotors are worn down to minimum thickness specifications and cannot be resurfaced without exceeding the “machine to” or “discard” thickness.
General Motors TSB #00-05-22-022 says rotors should only be resurfaced if the rotors are badly scored and the depth of the grooves exceeds 0.060 inches (1.5 mm), or there is excessive corrosion on the rotor faces, more than .003 inches (.080 mm) of lateral runout, or more than .001 inch (0.025 mm) in thickness variation.
GM also says that rotors are not to be resurfaced in an attempt to correct the following conditions: noise/squeal, cosmetic corrosion, routine pad replacement, or discoloration/hard spots. GM also says that unnecessary resurfacing only shortens rotor life — unless GM tells you to do so in a technical service bulletin to eliminate a brake noise problem.
ROTOR FINISH
Regardless of when or how the rotors are resurfaced, the surface finish should meet OEM specifications for good braking performance, pedal feel and quiet operation. Brand new OEM rotors and aftermarket rotors from a quality supplier typically have a surface finish that can vary from 15 to 80 microinches. Most brake experts say the best finish is 50 microinches or less, though a finish in the 60 to 80 microinch range is acceptable.
When a rotor is turned on a brake lathe with SHARP bits (we emphasize the word “sharp” because it is absolutely essential to a quality rotor finish), and a feed rate that is not TOO FAST, the rotors will have a finish that meets these recommendations.
Lath bits get dull with use, especially if they are cutting rust. Some experts recommend rotating the lathe bits every 7th brake job (every 14 rotors) to maintain the best surface finish.
The type of tool bits used in a brake lathe also affect the surface finish. Round carbide bits generally produce a smoother finish than angular bits and allow a faster crossfeed rate to save time. Titanium bits with parallel, peripheral ground edges are considered premium bits for this type of work. On a bench lathe with a spindle speed of 100 to 150 rpm, a crossfeed rate of .002 in. to .005 in. per revolution should produce a relatively smooth, high-quality finish. On bench lathes with adjustable spindle speeds, the spindle speed should be slowed down for larger rotors. One manufacturer suggests the following speeds: for 10-inch and smaller rotors, use 170 rpm; for 11- to 16-inch rotors, use 100 rpm; for 17-inch or larger rotors, use 60 rpm.
The depth of cut is also important. Take off as little metal as is necessary to clean up the surface, and keep the depth of the final cut to .002 to .008 inches. If a rotor is in really bad shape, multiple cuts should be used: one or more rough cuts followed by a shallow final cut.
When turning composite rotors, be sure to support the rotor properly with large bell clamps or adapters to prevent flexing and chatter. Make sure the brake arbors are clean and there is minimal play and runout in the lathe (when was the last time somebody actually calibrated your lathe?). And if you are a real stickler for details, use a dial indicator when you mount the rotor on the lathe arbor to keep runout to .002 inches or less.
THE FINAL STEP THAT EVERYBODY FORGETS
If you turn your rotors with sharp bits, and use the proper feed rate and depth of cut, there’s probably no need to apply a nondirectional finish as a final step. The rotors should be ready to install when they come off the lathe — provided you clean them first. That’s the final step that most technicians forget.
Not washing the rotors after they have been turned can leave a lot of junk on the surface that can embed itself in the pads and possibly cause braking as well as noise issues when the rotors are installed. Spraying the rotors with some aerosol brake cleaner and then wiping them off is better than nothing, but it really doesn’t do a very good job of removing surface debris. What you need is warm, soapy water, a good stiff brush and a little elbow grease.
WHAT ABOUT NEW ROTORS?
New rotors, either OEM or aftermarket, are supposed to be finished to specifications and ready to install out of the box. There should be no reason to give them a “clean up” cut. If they do, you need to find a different rotor supplier.
A recent Babcox survey found that 35% of our readers are still machining brand new rotors before they install the rotors on their customer’s vehicles. Every rotor manufacturer we have ever spoken to says this practice is NOT necessary, and is counterproductive because (1) it shortens rotor life, (2) may leave a rougher finish on the rotors than the factory finish and (3) may cut runout into the rotors. The manufacturing tolerances for rotor runout on most new rotors averages about .002 inches or less, with a maximum upper limit of .004 inches. Some cars (notably 1997-2002 Chevrolet Malibu, 1997-1999 Olds Cutlass, 1999-2002 Olds Alero and 1999-2002 Pontiac Grand Am) are unusually sensitive to rotor runout. As little as .0015 inches of runout on these cars may produce noticeable pedal pulsations. So if a brand new rotor has .004 or more inches of runout out of the box, and your brake lathe is so accurate it can cut rotors with less than .002 inches or runout, do it if you think it is necessary. Otherwise, don’t cut new rotors — but do wash them before you install them.
NONDIRECTIONAL FINISH
OK, you’ve read the reasons for not resurfacing rotors unnecessarily. You’ve also read how to get a good rotor finish that should meet OEM surface finish requirements, and that new rotors should not require any additional finishing. But what if you still want to apply a nondirectional rotor finish anyway for additional insurance? Go right ahead if you think it reduces noise or the risk of a comeback.
The theory behind a nondirectional finish is that the scratches on the surface go in various directions, so there is less change of pad vibration and noise. The nondirectional finish doesn’t last forever (maybe a few hundred to a few thousand miles of driving depending on brake usage), but it lasts long enough for the new pads to seat and to keep the customer from noticing any noise from the newly installed pads.
Nondirectional rotor finishes can be applied a number of ways.
A nondirectional finish can be applied with an abrasive disk in a drill or a special rotor refinishing brush. As with the sanding block, you want to give each side about one minute of sanding while the rotor is rotating on the lathe. Also, follow the manufacturers recommendation for rotational speeds. Another method is to hold a pair of sanding blocks wrapped with #120 grit sandpaper firmly against both sides of the rotor for about one minute while it turns on the lathe.
Sanding knocks off the sharp peaks on the surface of the rotor, and generally improves the surface finish by 15 to 20 microinches (smooth is better, right?).
Sanding a rotor while it is laying flat on the floor or a table also works, but there’s a risk of getting a slightly uneven finish. That you don’t want because even a slight variation in surface thickness may lead to a pedal pulsation and/or uneven rotor wear. So go easy and just lightly buff the surface of the rotor.
And don’t forget to wash off the rotors when you’re done.
WHAT REALLY CAUSES NOISE
A nondirectional finish can reduce initial break-in noise, and help suppress noise for awhile. However, brake noise can still occur if there are vibrations between the pads and rotors, or if the pads are inherently noisy (which is usually more of an issue with semi-metallic pads than nonasbestos organic or ceramic pads).
Brake squeal is caused by undampened high frequency vibrations. When the brakes are applied and the pads contact the rotors, tiny surface irregularities in the rotors act like speed bumps causing the pads to jump and skip as they rub against the rotors. If the pads are not dampened by shims (external or internal) or are loose in the caliper mounts, they shake and vibrate and may produce an annoying high pitched squeal.
The vibration of the pads against the rotors can also create harmonic vibrations in the rotors that causes them to ring like a cymbal. Depending on the metallurgy of the rotors and the design of the cooling fins, some rotors may ring louder than others — regardless of what kind of surface finish they have.
Consequently, you can do everything right when refinishing a set of rotors, and even apply a nondirectional finish, and still end up with a noise problem if the pads or rotors themselves are inherently noisy. Switching to a different brand of brake pads or substituting a different type of friction material may be necessary to get rid of the noise.
A tip for reducing noise-producing vibrations is to apply a high temperature brake lubricant to the backs of the pads, and the points where the pads contact the caliper. Lubricating the caliper mounts, shims and bushings is also recommended to dampen vibrations here. The lubricant acts as a cushion to dampen vibrations. It also helps the parts slide smoothly so the pads wear evenly (uneven pad wear is a classic symptom of a floating caliper that is sticking and not centering itself over the rotor).
The type of rotors on the vehicle can also affect noise. Some grades of cast iron are quieter than others. That’s one of the reasons why composite rotors have been used on various vehicles over the years. Besides being lighter, composite rotors can also be quieter when the right grade of cast iron is used for the rotor disk. Replacing a composite rotor with a solid cast rotor changes the harmonics and frequency of the brake system, and may increase the risk of brake noise on some vehicles. Also some low priced rotors may use a lower grade of cast iron that is noisier than the OEM rotors they replace.
Something else that can be done to reduce noise during the critical break-in period for a new set of pads is to spray the rotors with an aerosol product designed to dampen noise and assist pad break-in. The coating doesn’t last very long, maybe 50 to several hundred miles, but it is usually long enough to eliminate any noise complaints. These products typically contain lubricants and microfine aluminum particles. According to one manufacturer who makes a spray-on rotor treatment, the particles form a molecular bond with the rotor surface to form a “composite” surface that allows for a more controlled burnish as the new pads seat in. The result is less vibration, no annoying noise and a smoother feel.
-Larry Carley
I'm guessing this "aerosol" that is mentioned at the end here is CRC's De-Squeak Conditioning treatment for brakes. I didn't think to use it on new rotors after washing them, but it is a good idea.
alexxxx89 is offline
