Finished New Brakes, Still Hear Contact - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 02-19-2014, 09:58 AM Thread Starter
I finally finished (after waiting 10 days on parts that i paid for 3 day shipping for, ugh) painting and changing the rotors, pads, ss guides and guide pins. After following PowerStop's break in procedure, I can still hear the pads in contact with the rotor without brakes being applied. There is no more wheel shudder or vibration upon braking, which is nice, but I don't want the pads to glaze like the old ones. Suggestions?
Edit: The pads aren't dragging enough to make one side noticeably hotter than the other, nor does the wheel pull, but I can hear it on the driver-side.
alexxxx89 is offline
post #2 of 6 (permalink) Old 02-19-2014, 10:03 AM
Did you clean your guide pins and relubricate?
post #3 of 6 (permalink) Old 02-19-2014, 10:05 AM
Did the piston push back nice and easy?
post #4 of 6 (permalink) Old 02-19-2014, 10:18 AM Thread Starter
coby_7, the guide pins are new carlson brand, lubricated generously with syl-glide lube. I had to reuse the bushings from the old lower pins because the raybestos pg ones are way too thick. There was almost no movement with them inside the bracket. I also reused the guide pin boots, also bc the raybestos ones do not have enough clearance on the inside.
money_man, both piston boots were kind of deformed, but i after cleaning with a nylon brush and some finessing with a lubed up qtip they popped back in no problem. And the pistons compress with very little effort (although there was some grease from unknown source around the boots when i cleaned them up with the brush).
This is how it looked before
[IMG][/IMG]
post #5 of 6 (permalink) Old 02-19-2014, 12:32 PM
Watch out with the way that boot is positioned. It may tear and leak fluid.
post #6 of 6 (permalink) Old 02-19-2014, 03:55 PM Thread Starter
That was pre-finessing. While retracting the piston with a C clamp, i worked the boot back in with a qtip and lube. Worked like a charm. I think there is buildup around the edge of the piston that is preventing it from going back on its own..
