Bent Sub Frame - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
LinkBack Thread Tools
Old 05-17-2014, 06:33 AM Thread Starter
Bent Sub Frame
hello all,
my son hit a curb in our 2006 cobalt and the mechanic report says the engine cradle sub frame is bent. where can I find a manual that will show how to replace it?
thank you in advance
Tony F.
kingsfisherman is offline
Old 05-17-2014, 03:54 PM
Pretty simple, support engine and tranny and about 16 bolts later remove and replace sub frame. I will try to find the GM maintenance manual info for you.
Old 05-17-2014, 04:58 PM Thread Starter
awesome
thank you Coby, I hope it is that easy because right now the car is undrivable.
Old 05-17-2014, 05:03 PM
Old 05-20-2014, 05:41 AM Thread Starter
Thumbs up thank you
much appreciated Coby.
Old 05-20-2014, 09:55 AM
beaverG5GT's Avatar
My subframe was removed, when i couldn't get out the TCABs. The rack was left attached to the steering knuckles. Just used a long drive extension and took rack bolts from the top.
beaverG5GT is offline
Old 05-24-2014, 02:43 PM Thread Starter
interchange?
now I'm looking for another sub frame, does anyone know what years or other models the sub frame is interchangeable with?
thank you,
Tony F.
Old 05-24-2014, 03:36 PM
I believe it is the same for all Cobalts, G5,Pursuit and saturn ION.
GM# 15918781 (#27) seen here on ebay for description purposes only. Don't pay that amount for it. You should be able to find a good one at a junkyard for less than $200.
15918781 | eBay
Old 05-28-2014, 09:41 AM
jrsmith's Avatar
Looks like I gotta drop my sub-frame too (the bolt holding the right rear control arm bushing is not turning out). Thanks for the instructions Coby7. What I am not clear on is how to brace the engine/tranny (above or below?) and how to remove the sub-frame (will I need to get a custom jack, or can I just use a normal floor jack with a long piece of wood on it or something.
jrsmith is offline
Old 05-28-2014, 10:21 AM
Don't think you need to drop sub-frame for that nut, if you know somebody who can weld it in place then you can undo the bolt while the nut is still hot from the weld.
