Front Sway - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 42 (permalink) Old 07-03-2014, 06:15 AM Thread Starter
Front Sway
Was curious to know the effects of upgrading to a thicker bar. I've heard it's a pita to do, and may negatively affect cornering? If so, would it be beneficial on a drag setup? Also, do the endlinks play a big role in the handling equation?
post #2 of 42 (permalink) Old 07-03-2014, 06:30 AM
If you now have understeer in the corners upgrading the sway bar will help. End links just hold the swaybar in place, they have no effect on performance.
post #3 of 42 (permalink) Old 07-03-2014, 06:48 AM Thread Starter
I see. Does it increase steering effort?
post #4 of 42 (permalink) Old 07-03-2014, 07:08 AM
It does help in most cases, but too can be an issue. Which bar were you looking at? I would go with ST, SS LNF, or Eibach. Im going to add a front sway bar by Eibach, then go with ZZP rear. I heard with good suspension, it can ride like on rails.
post #5 of 42 (permalink) Old 07-03-2014, 07:19 AM
Same, don't go to big unless you autocross. If you're going to drag race it won't help at all in a straight line, unless you lose control and want to save it.
If you want instant power for drag racing find the smallest radius wheel that will fit in the front.
post #6 of 42 (permalink) Old 07-03-2014, 07:21 AM
agreed. Sway bars are to decrease body roll during cornering. What most people use on their cobalt is a 23mm front sway bar, which is the stock LNF size. I had on my MSP, front 28mm, rear 23mm., but i used it for auto-X.
post #7 of 42 (permalink) Old 07-03-2014, 07:22 AM Thread Starter
Like a 13" wheel and a tire with half a mile of sidewall?
post #8 of 42 (permalink) Old 07-03-2014, 07:45 AM
No,no smallest wheel radius, accomplish it the way you want. A 10% diameter gives you about 10% more torque and horsepower to the pavement. You won't be able to go as fast top speed but you'll get there a lot quicker. 14'' rim with 255/40's and for instance. You'd take off at a light like a bat out of hell. 13'' even better if you can find one that fits over the caliper.
post #9 of 42 (permalink) Old 07-03-2014, 03:32 PM
Some people disconnect the front swaybar for autocross so I don't see why you'd want an upgraded one is the springs are good.
post #10 of 42 (permalink) Old 07-03-2014, 03:36 PM Thread Starter
Not really intetested in autocross. City driving in Montreal is all the autoX I'll ever crave.
