2005 Base Model ABS? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 9 (permalink) Old 08-11-2014, 04:53 PM Thread Starter
Question 2005 Base Model ABS?
Hey guys,
I need to replace a front wheel bearing, not sure if my car has ABS though.
No user manual came with my used car. I have already bought the part assuming it has ABS. So the new wheel bearing does have the ABS connector. I dont want to take it all apart just to find that it doesnt have ABS and have bad luck trying to return the part just so they wont have the one i need in stock.
Does anyone know if there is some place i might be able to use my VIN to find out the information i need?
Thanks
samsnerk is offline
post #2 of 9 (permalink) Old 08-11-2014, 06:17 PM
Dustinb855's Avatar
If its a base 2005 model Im 99% sure that it doesnt have ABS and you bought the wrong part. Easy way to tell is just slam on your brakes. If the pedal is pulsing you got abs. Trust me you would know if you have abs or not.
Dustinb855 is offline
post #3 of 9 (permalink) Old 08-11-2014, 06:20 PM
crawl underneath and see if it has wires coming out the back of the wheel bearing, if it does then you have abs. or look under the hood and see if you have an abs box
look something like this i would i guess (mine dont have abs so i dont know for certain9
2007 g6 gt family car
terry06 is offline
post #4 of 9 (permalink) Old 08-11-2014, 06:22 PM
Dustinb855's Avatar
This as well^
post #5 of 9 (permalink) Old 08-11-2014, 06:54 PM
The ABS module is bolted to the rad support drivers side. Don't worry though because the ABS hub fits in the place of a non ABS hub. You just spent too much that's all if you don't have ABS.
post #6 of 9 (permalink) Old 12-15-2014, 12:05 AM Thread Starter
i know my reply is a little late but it turned out my car does not have abs. and the bearing replacement went well. thanks!
samsnerk is offline
post #7 of 9 (permalink) Old 12-18-2014, 07:18 PM
Gopi Hira's Avatar
the easiest way to check for ABS is to turn your key onto accessory before starting the ABS light should turn on and after a few seconds it will turn off...letting you know that ABS is working properly ....and im 99% that your hub can be installed just do not connect it...it would only be a problem if you had a ABS car and bought a non-ABS hub then you would get the light and the system would be deactivated with traction control as well...
Gopi Hira is offline
post #8 of 9 (permalink) Old 12-19-2014, 05:45 AM
hailcesar75's Avatar
check with gmpartsgiant.com. just type your vin and it will give you parts for your vehicle.
hailcesar75 is offline
post #9 of 9 (permalink) Old 12-20-2014, 08:02 AM
My 2006 base G5 does not have ABS, finding that out for the first time was a bit of a shock. Brakes locked up in the wet and I stalled the motor. I believe it was optional on the base models (~$400).
abs , hub bearing , wheel bearing
