FE5 05-07 or 08+ Control Arms ? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 2 (permalink) Old 09-15-2014, 06:15 PM Thread Starter
Went in for a 10$ inspection at firestone for kicks and because of a vibration and uneven tire wear.. Guys are saying that the shocks and struts are bad(no big deal, already replacing those) and that the front passenger balljoint is worn. Qouted me around 2 grand to fix all that(It was hard to not laugh..ofcourse I rejected the work)
Anyways..
I figured since I'm doing a suspension overhaul and the ball joint is bad...might as well replace the control arms.
So which should I get, I believe the 05-07 fit without any changes/bolt on..while the 08+ I believe I would need to change the knuckle...if so how hard is that to do?, Is it recommended.
Lastly do those control arms come with a ball joint packed? and I assume I need to get bushing.
Thanks in advance,
climertech is offline
post #2 of 2 (permalink) Old 09-15-2014, 07:05 PM
Look for a set of used FE5 control arms, drop the $200 on Powell's trailing bushings and you'll love them.
For example, a quick search on ebay, there are some from the LNF for cheaper, although I wouldn't recommend it.
06 07 Chevrolet Cobalt Passenger Right Front Lower Control Arm FE5 IC 1461 | eBay
06 07 Chevrolet HHR Cobalt Passenger Right Front Lower Control Arm 8679 | eBay
06 07 Chevrolet Cobalt Driver Left Front Control Arm FE5 SS 16971 Morad Parts | eBay
