Coilover Install Questions - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 4 (permalink) Old 10-05-2014, 12:56 PM Thread Starter
Soaxin's Avatar
So I got d2racing coilovers and installed them but I don't think I have them installed right. The sway bar rattles like crazy. How far up should the end link adaptor be on the strut? I have it up so it's even with the end link when jacked up. By doing thathis I may have preloaded the springs. Should I put the adaptor up as high as it can go with no preload on the spring? Also on the rear should the perch be on top of the spring or the bottom. Search but didn't find info I could understand. Lol oh and it's a 2007 lsj
Soaxin is offline
post #2 of 4 (permalink) Old 10-05-2014, 01:12 PM
SilverBullett's Avatar
I had the k sport which is the same company as D2. As for the rear I think the spring Pearch goes on top of I remember correctly, I called them but forgot what they said. I had mine on bottom and it was fine. Did you get new shorter endlinks or are you using the stock ones. I had my coils almost all the way down so I didn't have much room to move the little swivel thing they connect to.
SilverBullett is offline
post #3 of 4 (permalink) Old 10-05-2014, 06:36 PM Thread Starter
Soaxin's Avatar
I.got new endlinks but same size as stock
Soaxin is offline
post #4 of 4 (permalink) Old 10-15-2014, 01:08 AM
I've installed a handful of rotors on light duty race cars and regular cars over the years, ranging from hi-performance slotted to cheapo budget no-name rotors. I'm no pro mechanic, just an avid auto-crosser and DIY'er, but I think these are the best bang for the buck. If anything, avoid the no-name stuff or serious budget stuff. They rust like crazy, and do not have a consistent enough run-out which may lead to brake judder. These come from a respected company and for their Black XD for long lasting corrosion protection Cross Drilled Rotors kit paired with kevlar or carbon brake pads is definitely the way to go for your Chevrolet Aveo.
ChevyFan512 is offline
