2006 LT Vs SS Suspension - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
LinkBack Thread Tools
Old 11-11-2014, 08:49 AM Thread Starter
JBronski's Avatar
What are the major differences between the suspension in a LT and a SS supercharged? Is it worth upgrading to?
JBronski is offline
Old 11-11-2014, 08:53 AM
swanman35's Avatar
Upgrade to the lnf suspension. From the turbo ss
swanman35 is offline
Old 11-11-2014, 10:26 AM
This.
Cheap and effective. SS/TC Struts and Shocks are actually better than Koni Yellows for a fraction of the price.
MP81 is offline
Old 11-11-2014, 11:02 AM Thread Starter
JBronski's Avatar
How are they better? Stiffer? Better cornering?
JBronski is offline
Old 11-11-2014, 11:06 AM
Better than...the Konis, or the base suspension?
GM Developed the SS/TC on Nürburgring, ultimately leading to a superior product over the Konis.
MP81 is offline
Old 11-11-2014, 01:39 PM Thread Starter
JBronski's Avatar
Basic mainly
JBronski is offline
Old 11-11-2014, 01:53 PM
I changed the rear springs and shocks on my LT for the SS springs and shocks. Made the car more stable at highway speeds and I don't regret. Actually think of doing the same thing to the LS because at 110KPH it isn't the sturdiest riding car.
Old 11-11-2014, 03:23 PM
FE1s are a deathtrap. I never thought I'd ever get oversteer on a FWD until I took an offramp at 20 kph over the advised limit. Upgrade now if you use your car as more than basic transportation and if you value your life.
Old 11-12-2014, 06:04 AM
Originally Posted by JBronski View Post
Basic mainly
Stiffer struts/shocks that can handle the higher spring rates of the SS/TC springs - also makes them much more suitable than the FE1 shocks/struts to handle lowering springs.
A larger front sway bar and cast aluminum control arms (vs stamped/welded steel) round out the changes for the most part.
I'm running SS/TC FE5 Struts and Shocks, with SSC lowering spring (one of the top handling springs, and yet still rides comfortably and provides a good drop), with SS/SC FE5 control arms and front 24mm swaybar with Moog end links. I also have the Powell Hardcore rear sway bar. Body roll just doesn't happen anymore.
MP81 is offline
Old 11-12-2014, 07:10 AM
Come spring I plan to overhaul my mediocre suspension setup (Currently running SS/TC shocks & struts and Pedders springs). I want to use YYZs, LSJ control arms, Powell CABs, Powell hardcore XXX rear sway, LNF 23mm front bar, Powergrid endlinks and Timken wheel bearings. There are a few more parts but those have priority.
