SS/TC Suspension but at Base "4x4" Stance? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 28 (permalink) Old 05-15-2015, 11:04 AM Thread Starter
I want the SS/TC suspension, but I want it at the base 4x4 height. I've read that it lowers it 10mm, I've also read that from base to SS/TC is actually almost 2", either way I don't want the drop.
1.) Is it the strut/shock or the springs that causes the drop, I've always assumed it's the spring.
2.) If You swap out for ss/tc struts and shocks, but get a spring that maintains Base height but with the same spring rate as the ss/tc, will the strut/shocks perform the same? Or are the shocks/struts designed for the drop?
3.) Can anyone, with certainty, tell me the spring rates for the front and rear SS/TC? I've read 154 front, 160-228lbs progressive rear, but I can't confirm. That would seem soft considering the way everyone says it handles better.
Thanks in advance,
C
chillsworld is offline
post #2 of 28 (permalink) Old 05-15-2015, 11:17 AM
Unless you go out have have a custom spring made you're not getting 08-10 FE5 without lowering the car a little. Go look at pictures of stock SS/TC cars since they made them in both sedan and coupe you can get a good idea of how much lower it is.
They shocks/struts are valved better with a stiffer spring and you won't get much besides a harsher ride if you leave FE1 in with FE5 shocks/struts.
I could text powell for the rates but I know he has them posted somewhere I'll try and look.
post #3 of 28 (permalink) Old 05-15-2015, 12:05 PM Thread Starter
Thanks, but I don't want to leave FE1 springs in, I want to put "taller" springs with the same rates as the SS/TC springs. There's a ton of springs made by a bunch of different companies for racing/lowering/lifting just about any car made... I just have to know what to look for!
And that would be awesome if you could find the rates, you'd think it would be readily available information
~C
post #4 of 28 (permalink) Old 05-15-2015, 06:56 PM
My I ask why you want to keep the stock FE1 ride height? If it's clearance you're worried about, the FE5 setup (shocks & springs) will do fine unless you wanna tackle Moab or something. I have FE5 shocks and Pedders springs and have only gotten badly stuck twice that I can remember and both times it was due to ice freezing around and under my car locking me in place. I'd recommend carrying a shovel and a good set of traction aids if your winters are particularly harsh like mine.
post #5 of 28 (permalink) Old 05-16-2015, 07:36 AM Thread Starter
If there's snow, then I take the SUV which has shovel/ax/recovery gear/etc. I want to keep FE1 ride height because I take it places where it needs it, it's that simple. I want the better handling characteristics of the TC setup, that way I can push the car harder on pavement and washboard gravel roads.
A quote from a passenger last weekend:
"Man, you're nuts, I wouldn't take my truck up here"
Thanks for the input though!
~C
post #6 of 28 (permalink) Old 05-16-2015, 10:09 AM
swanman35's Avatar
The ss suspension isnt insanely lower than base. I don't think it would cause too much trouble with base bumpers beinghigher up
swanman35 is offline
post #7 of 28 (permalink) Old 06-28-2015, 08:35 PM
Cliff's Avatar
Out of curiousity does anyone have a base LS/LT on FE5 shocks/springs combo, a pic request? That or the eibach pro kit is lowest i'd go as I have a big ass ZZP resonator sticking low. Otherwise i'd look into YYZ's
Cliff is offline
post #8 of 28 (permalink) Old 06-29-2015, 08:04 AM
xfe2008's Avatar
I literally just about walked outside to take a picture for you, but then realized my car is getting a new exhaust welded on. I will try and get you a picture later today. I am on FE5 (lnf) springs and Konis. They aren't low, but they handle well.
"Ask not what my monster truck can do for you, ask instead what you can do for my monster truck."
-JFK
And on this day the good Lord said, 'Let the big wheeled vehicle pass on into Heaven.'
Speed isn't everything. Sometimes, you just need a little style and flair in your monster trucking.
xfe2008 is offline
post #9 of 28 (permalink) Old 06-29-2015, 02:04 PM
xfe2008's Avatar
Sorry for the bad pictures since its still raining but here they are.
Its definitely lower, even though it doesn't look like much, but it also handles a million times better. (Ignore the ugly wheels that need to be painted or replaced)
This is front wheel gap (tough to get a picture of measurement)
And this is the rear wheel gap.
It also sits more level than it did with fe1 springs
-JFK
xfe2008 is offline
post #10 of 28 (permalink) Old 06-29-2015, 04:40 PM
Looks about the same it did on my FE5/Pedders setup. People would never know it was lowered unless you told them.
Of course I don't particularly like using the term 'lowered', since these springs are not for low, but rather for handling.
Stock 2.2s do look like monster trucks to me now tbh
