Caliper Painting Gone Wrong - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 11 (permalink) Old 07-04-2015, 08:44 AM Thread Starter
JBronski's Avatar
So I decided to paint my calipers yesterday. After I reinstalled them I attempted to bleed my brakes. Both the rear brake bleeder valves were frozen shut, so I decided to just bleed the front calipers. After I finished bleeding the system, I tried to test my brakes and they were extremely soft! Any ideas on how to fix this?
JBronski is offline
post #2 of 11 (permalink) Old 07-04-2015, 09:54 AM
You must still have air in the system. Try spraying WD40 and hammering around the bleeder valve and tightening it a little to try and dislodge it. In an extreme case, you might consider putting a torch to it but keep that as a last resort.
post #3 of 11 (permalink) Old 07-04-2015, 10:06 AM
When I read the subject line I was expecting something like this lol
colodude18 is offline
post #4 of 11 (permalink) Old 07-04-2015, 10:15 AM
Because red paint decreases stopping distances by at least half. True fact.
post #5 of 11 (permalink) Old 07-04-2015, 02:40 PM Thread Starter
JBronski's Avatar
Well I bled the brakes 3 more times, didn't see any air bubbles coming out. The brake pedal is a little stiffer but still waaayyy to soft. Any other ideas?
JBronski is offline
post #6 of 11 (permalink) Old 07-04-2015, 03:51 PM
You have to bleed the back brakes, no way around it.
post #7 of 11 (permalink) Old 07-04-2015, 04:54 PM Thread Starter
JBronski's Avatar
I replaced the brake bleeder valve in the back brakes so all of them were bled properly.
JBronski is offline
post #8 of 11 (permalink) Old 07-04-2015, 05:03 PM
You have to bleed back brakes first then front. If they still feel spongy you still have air.
post #9 of 11 (permalink) Old 07-04-2015, 08:47 PM
Specifically, back right first, then back left. Start the farthest from the master and work your way towards it.
MP81 is offline
post #10 of 11 (permalink) Old 07-04-2015, 11:09 PM
Dustinb855's Avatar
This^
WRX are as nice as they get.
Dustinb855 is offline
