2005 Cobalt Stuck in Park - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
Tech Problems Technical problems with the site or your account
post #1 of 3 (permalink) Old 08-09-2018, 07:48 AM Thread Starter
Stuck in park and traction control light is on
Jim732 is offline
post #2 of 3 (permalink) Old 08-09-2018, 02:10 PM
It could be a fuse or the brake light switch, the easiest way to test these are to see if your brake lights are illuminating when the brake is pushed. If they do not illuminate then it's either one of those, the fuses will be the easiest to check first. If the brake lights work fine then it might be the shift interlock solenoid, these can act up if a drink is spilled and it manages to leak down onto the solenoid which is located under the console right next to the shifter. If you clean the solenoid and it still acts up you may need to replace the solenoid. These are the easiest things to check first, hope this helps
check these 2 vids
https://youtu.be/SgJzbVufT3M
https://youtu.be/jIJ12q3aJb8
vincom is offline
post #3 of 3 (permalink) Old 08-10-2018, 08:49 AM Thread Starter
Does anyone have the wiring diagram for the shift lock solenoid?
Jim732 is offline
