Hello thanks in advance for any help on this one, the sun roof drain clogged the rear right one causing the trunk to fill up with water. The floor on the rear passenger side was also flooded After removing seats and carpet drying everything out the Car ran for several days it now has the engine disabled warning and reduced power warning intermittently. error code P0601. I can clear the code start and use the car once I shut it it will either not start or start and shut down after a few minutes clear the code and it will run fine again for awhile. The amperage sensor on the negative battery cable was under water and I replaced that . I have 5 V at the maf and throttle body could the wire harness under the carpet being partially submerged cause the PCM to fail? Any suggestions where to look next.
2005 Cobalt 146,000 miles
