this is my gfs sons car and it was running and driving until he stripped off all the clutch face on one side of the clutch disc, it was still starting then, but would not motivate at all
so myself and a helper pull tranny out and replace clutch asembly, get it all together and this is what I am working with: no warning lights on cluster, except antitheft one is on, no crank, and of course wont start with no cranking..
my helper I believe hooked up the plugs into computer wrong and it blew the number 25 fuse inside on side of console, also pcm fuse in fusebox under hood
replaced those, test lighted all fuses in both boxes and 50 amp back by battery...all good..
oh yes also did the reprogramming of key by leving it on for 10 minutes, 5 seconds off, on for 10 mintes, off for 5 more, then on for 10 minutes more....no difference....
thanks all
thanks all
