So I have an 07 cobalt 2.2 that’s getting misfires on cyl 3 p0303. It also had secondary air injection check valve errors. It shows actual
Misfires on the scan tool, sometimes a few, sometimes over a thousand in 130 miles. I swapped coil packs with other cylinders, no change, replaced plugs with new ac delco iridium, cleaned and moved fuel injectors to different positions. After the injector cleaning it was ok for 300 miles and came back. Changed MAF sensor, changed upper O2 sensor. It will randomly come and go with no reason. Cleaned all connections on injectors and coil packs, checked for bare wires, checked and cleaned connection to injector harness, changed check valve. Any ideas where to go next?
