Won't start doesn't click when turning key and battery good I can pop start the car what could be the problem
Starter motor or possibly a fuse. Are you sure the battery is powerful enough, hook up another car and try to jump start it and see if it has the same issue.
dash cluster went out one day the car would start took my brother up to the store and back and then would not start change the starter other day got cluster working but will not when I changed the starter disconnect the battery now the cluster don't work
