i have a 07 cobalt and i bought the expensive harness that is needed to put in a aftermarket cd player and i hook everything up and when i turn the car on the cd player wont come on and my gauges do not work. if i unhook it everything works. also it came with a fuse relay is that necessary. help please thanks
sounds like you have a wired crossed somewhere that is shorting out when you plug it in i would check the wiring and make sure you have a remote wire pluged in for the deck other wise it wont come on
