1 - 19 of 19 Posts
My 09 ls seems to be throwing up too many codes for everything here to be going wrong at once.
I had a tire separate, and it took the inner fender with it. When I pulled over, it was wrapped around the axle/ suspension. Nothing looked damaged so I put the spare on and drove home. Everything seems fine, but, but about a day after I put new rims and tries on it a few days later (it was already planned, so I wasn't too bent out of shape about the separated tire) it started throwing up trouble codes left and right. I tried resetting the ecm and they come back as soon as the car starts moving again.
O'Reily's didn't give me the specific codes I had, but had mentioned the o2 sensors and the maf. I dug out my pos obdII scanner and got the codes, but it doesnt show the last digit of each, but from reading through the list of dtcs, it looks like they're;
P0031, P0032, P0051, P0052, P010?, P013?, P014?, and P044?
Would the tire have anything to do with this, maybe having knocked a ground wire loose or something? Could all these things really be wrong, or is there just a simple solution(hopefully). I need to get this taken car of, my inspection is up this month, and I can't get it inspected until there's not CEL.
Looks like you blew the Exhaust voltage fuse. Check in the underhood fuseblock. This fuse supplies voltage to the HO2s and MAF sensor plus a few others like MAP and intake temp
I had read that on another site. I thought I had checked all the fuses before, but I guess I missed that one. Went out to double check, saw it was blown. reset the ecm and let it run for a few minutes. Seems to be working now. I have to go pick up my fiance from work here in about half an hour. Will report whether the MIL comes back on.
Thank you for the help.
---------- Post added at 11:06 PM ---------- Previous post was at 10:01 PM ----------
Well, down the road and back and no codes. Thank you Coby for that bit of knowledge which has potentially saved me a ton of money.
electrical problem!
wont turn over,
fuel gadge wont read
low fuel warning
powersteering warning
battery is fine conections fine
im wondering what is incharge of fuel sending/reading
ECM- tryed a used one fuel still wont read (NO CHANGE
TCM- in mail will arive in few days
BCM- looking for a cheap new one
trying to figure it out before i take it to the dealer I know they will have to program things like ecm, tcm, and bcm
I think you broke one of the two engine grounds or both, the one in front where the transmission and engine bolt together. This is the ground for TCM and ECM, also for fuel sending unit and a bunch of sensors too.
coby is my hero
Ok so I checked all the grounds and cleaned them, Same problem no change. Car wont turn over fuel gadge wont read, ps warning, abs warning, low fuel warning, any ideas????
should I check if the ECM is getting power? and if so how?????
Levee
Checking for power to the ECM is easy. Get the wiring pinout for the ECM, find the power and ground wire and use a volt meter and connect leads, will tell you if you're getting voltage. Sounds like a ground to me, but could be the ECM going out.
If you read codes ECM has power. Pull the fuses one by one check them for continuity and re-install flipped from original installation. This cleans contacts and seats in different spot. Especially the ECM/TCM fuse in the BCM fuse block.
That doesn't mean ECM is getting power. OBDII has battery power all the time. You need a CANDi ready scan tool.
MAF sensor gets its power from ECM, if you have the 10 Volts there that means ECM is powered up.
Right where the transmission meets the engine in the front is Ground 105.
well the maf sensor has 11 volts, fuses are good, I hear the fuel pump, fuel gadge still wont read anything, car still wont crank over, is it possible the ecm is bad or???? If I cant figure it out soon I have to take it to dealer :(
1 - 19 of 19 Posts
