1 - 16 of 16 Posts
Hi all,
I'm new to this forum and in in need of some help.
my 2009 cobalt (LS 4 door) started shifting hard from 1st gear to 2nd. this only happens when I'm at a stopped light and drive off and when it shifts from 1st to 2nd it shifts hard that the you can feel the pull.
any advise what could it be. I would really appreciate.
its my daily driver car and its automatic transmission. the car has 176xxx miles. i just hope my transmission its not going out.
Thanks
When did you flush the tranny fluid and replace the filter?
it has never been done to my knowledge.
the dealer says it has a sealed transmission therefore the transmission fluid is lifetime.
Your dealer is a dumb a$$
---------- Post added at 12:55 PM ---------- Previous post was at 12:55 PM ----------
I'll bet you are a quart or two low
can i just add the quart myself or will i have to take it to the dealer.
i know the fill hole has a cap. do i just remove it and try to put the fluid in there?
or are there any specials tools needed??
thanks
Where do you think there is a fill cap for your tranny fluid? I've never seen an auto?
That is a vent cap, hold on let me find the thread for checking your fluid. Pretty sure that's not your problem though.
http://www.yourcobalt.com/forums/transmission/28236-check-plug-location-2008-cobalt.html
Did you check the "TCM" fuse? Pull it out of the slot to check it if it's good, check tabs for corrosion, flip 180° and re-install. If this doesn't solve it check the "TCM" ground strap (G105) on the transmission case front of engine.
Any DTCs? No DTCs means it isn't engine related, like sensors and such.
OK, check fuse first, also might want to check for transmission oil cooling lines make sure they haven't leaked, then your ground then I would go get the transmission fluid level checked if all these fail.
Discussion Starter #12
the cobalt stopped doing the hard shift for a few days. and then it came back. i checked the fuse its still ok. they are no leaks. nothing.
so my thing might be low fluid.
any thoughts??
Well fluid didn't go up for a few days then go back down. You might have a bad TCM ground. Pull the TCM fuse and check if this causes the same symtoms if it does than you most likely have an intermittent ground wire. Then if you have good wire with alligator clips ground the case of the "TCM" and take it out for a spin. If problem disappears you know you have a bad ground.
Discussion Starter #15
well i have checked the tcm fuse the ground wire and its still doing the hard shift.
it was fine all last week and today it started doing it again.
what ive notice it only does it when im coming to work and when im off of work it runs fine.
idk what the deal is here.
and i dont want go to the stealership lol
Did you remove the fuse to check it? Sometimes the fuse tabs corrode and just removing or replacing the fuse corrects the electrical path.
1 - 16 of 16 Posts
