I scrolled through a few pages and did a search and found nothing. So here's my problem. '08 cobalt and neither one of the 12v outlets work. I checked fuses inside car and under the hood and all is good. Anybody else with this issue?
First of all these have 2 seperate fuses. The one under the radio is the cigar lighter outlet and has a 15 amp in the underhood fuseblock. The accessory outlet in the console has a 20 amp fuse also in the underhood fuse block. This one you can check if your trunk button works fuse is good because both are on the same fuse. Maybe it's the fuse in your plug and not the outlets.
