21 - 40 of 72 Posts
Which is a good idea. Measure twice, cut once.
I imagine stroking would be a safer option than boring the motor. With an aluminum block there isn't much you can safely bore, and the further you go the closer you'll get to a catastrophic failure. This is where the extent of my knowledge starts to taper off. I'm still learning, just like you.
A more experienced engine modder would be able to tell you for sure.
Plain jane you pretty much got it.
The sleeves in these motors are steel, but they can fail if you have a bad tune. Higher compression means more power, less boost. But under a boosted application, can cause detonation. To prevent detonation, higher octane fuel and/or meth are highly recommended. I dont believe there are options to stroke the motor but to be honest, with the power you probably want, it would be pointless and expensive.
thanks for the advice
what i want is to build it so it's safe and reliable for daily driving but still has 300-350 hp and i'm hoping that building the engine right and putting a nice bullseye turbo from zzp will achieve that with a nice tune
hey are the wiseco pistons and eagle rods good for the 2010's? when i look on ebay it only goes up to the 2008's
I admire your ambition.
haha thanks, is that sarcasm?
---------- Post added at 08:11 AM ---------- Previous post was at 06:50 AM ----------
one more quick question, stock compression is 10:1 right? the wiseco pistons and eagle rods say its 8.9:1, that cool?
---------- Post added at 08:30 AM ---------- Previous post was at 08:11 AM ----------
lol one more and im done i promise. which gasket bore do you select for the head gasket?
theres a bunch of 87mm options but im not sure which one
yeah i kind of did just jump into it, but i mean im only 21 so i might as well live life and have some fun while i can. Besides having the people on here to help me through it makes it muuuch easier for me to do this. Give it a go!
Stock bore is 86mm. Keep that. 10:1 compression is stock. If you keep stock compression, you cant run as much boost safely. However you will have a good power band down low and up top. Just make sure you have a damn good tune
could possibly provide a link to the right headgasket? all the ones im looking at are 87mm :/ yeah i got this for rods and pistons:
Wiseco Pistons Eagle Rods Ecotec 2 2L 8 9 1 86 5mm Opel Cobalt | eBay
these the right ones? sure hope so cuz these are the ones people keep saying to get lol
---------- Post added at 10:03 AM ---------- Previous post was at 09:56 AM ----------
oh and trifecta is working with me to get the tune right. although am i going to need them to re-do it after i have the rods, pistons and headgastet done? looking to safely run maybe 15-20psi.
No those are not right. Your bore is 86mm not 86.5mm. Just search cometic head gasket for 2.2. Youre gonna want to get a retune just to make sure. If youre 07+ I would highly suggest getting tuned by someone with hptuners. Youre supercharged right?
---------- Post added at 01:09 PM ---------- Previous post was at 01:08 PM ----------
If not supercharged, what turbo do you plan to run?
greeeat, i already ordered them. i mean it does say that they fit the 2.2L cobalts.
ill search for that then and see what i can find. :)
i am turbocharged, i have the ZZP s252 i believe
Crap I was kinda hoping no one would see my mistake before I fixed it, why was I thinking Banker had the s256 I don't know.
I have an EFR6758 all Borg Warner turbos here.
21 - 40 of 72 Posts
